scrapdaddytatum Posted March 10, 2008 Share Posted March 10, 2008 im sending a car out to cali for a customer 97 outback 2.5 with new motor and trans and new exhuast too new cats and all will it pass cali emisions or do i need to do something extra to it???? Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted March 10, 2008 Share Posted March 10, 2008 As long as all the smog equipment that came with the car from the factory is still there, then it should. The car does not have to be a CA vehicle to pass CA smog... just has to have all the equipment that came with it from the factory. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted March 10, 2008 Share Posted March 10, 2008 Does it need to pass the exhaust sniff test too for nox and stuff like that? If it's in good tune I would think it would pass that too. Some tricks I hear is to make sure the engine is completely warmed before the test, leave vehicle idling at the testing station until your turn (don't shut off), and if necessary put a few bottles of isopropyl drygas in the tank. Maybe the vehicle is calif. emissions? Those were sold in lots of other states that required Calif. emissions too. I think there's supposed to be this door sticker if it is. My '96 underhood sticker says it meets Calif. emissions, but it does not have the door sticker, and a VIN# lookup says it is not calif emissions. Quote Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted March 11, 2008 Author Share Posted March 11, 2008 i have the barcode sticker but it doesnt say anything about cali emisions Quote Link to comment Share on other sites More sharing options...
nipper Posted March 11, 2008 Share Posted March 11, 2008 These things run so clean, it should pass with no problems. When everything went obdII, the line between cali and rest of the world emissions got really foggy. I wouldnt worry about it, it should pass with flying colors. nipper Quote Link to comment Share on other sites More sharing options...
NOMAD327 Posted March 11, 2008 Share Posted March 11, 2008 If you want to register it in CA, there is a method for doing it, it involves paying a couple of special taxes, and passing a local test, which a good running 49 state vehicle should be able to do. The local test will do a visual to make sure it is a completely original 49 state car in good condition, followed by a tailpipe check. You will then get a smog sticker, which will get you through for a couple years. They used to do roadside checks a lot, and would wave you through if you had a recent smog sticker. Quote Link to comment Share on other sites More sharing options...
ericem Posted March 11, 2008 Share Posted March 11, 2008 What PPM do you need to pass. My 93 Legacy with 307K that leaks every possible fluid passed with flying colours at 47 PPM. You need less then 200 PPM to pass here. Quote Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted March 11, 2008 Author Share Posted March 11, 2008 do you think after market cats will affect any thing??? i have real nice name brand cat that is odb2 compliant works great, never throws a code and water spits o plenty i think it would pass any smog test but we dont have them here so i got no way to tell Quote Link to comment Share on other sites More sharing options...
nipper Posted March 11, 2008 Share Posted March 11, 2008 please tell me they aren't eastern cats.... nipper Quote Link to comment Share on other sites More sharing options...
mbshop Posted March 11, 2008 Share Posted March 11, 2008 if it can pass the fed requirements then it will pass the ca test. cuz its all wheel drive it only has to pass the stationary test. also the ca specs are rather forgiving so i doubt you will have any problems. just make sure the stuff on the car is all there and its all working properly. george Quote Link to comment Share on other sites More sharing options...
newsoobdude Posted March 11, 2008 Share Posted March 11, 2008 scrapdaddytatum, as long as the car will pass Federal Smog Regulations, the car WILL be good to go on passing. One nice thing about Cali and the Smog Nazi's here are as long as it's a used None Cali car (one with more than 7500 miles if I remember right), that did not get the mileage coming into State (ie bought new car in NY and drove it to Cali with stops on the way) all you have to pass is Federal Smog (hence the Cali Smog sticker on Cali cars). Soo, as long as there is no Cali Smog Sticker you only have to pass Federal. Quote Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted March 11, 2008 Author Share Posted March 11, 2008 please tell me they aren't eastern cats.... nipper i used Goerlich Catalytic Converter they are suposed to be true odb2 compliant seems to work real good, acording to the o2 read outs Quote Link to comment Share on other sites More sharing options...
