More GM Alt. install help please (prob. solved)
So I get my new GM 100 amper into my '81 Hatch, all the wiring done super nice, new #6 power wire from alt to battery, ext. voltage regulator removed, dash light bulb and circuit checked, 12 gauge field sensor wire from the alt to the junction, everything triple-checked, works great...so I put in the fully charged battery in, turn the key and ...nothing. No power to the ignition switch. I checked it with my meter...no power. I checked all the fuses...good. I checked my wiring diagram...AHA! It shows the ignition switch power wire (large white one) directly connected to the main power wire from the alt to the battery (clearly and unambiguously).
I haven't seen this connection in any of the other write-ups, and I haven't seen this connection under the hood yet. I am about to go begin hunting it down starting at the battery/junction area, but I thought I would put this out there in case someone knows the exact location of this connection. I also entertained the idea that the ig. power is relayed off the original field sensor wire, but the wiring diagram does not show anything like that. Any thoughts?
FOUND IT! :banana:
Factory crimp about 16 inches down the alternator wire from the original junction connection. FYI.
I hooked it up. Got everything tidy. Turned the key and...it fired up like a new car. Voltmeter shot to 14.5 and didn't budge with headlights and wipers on. Headlights, wipers, and heater fan took it down to 14v :grin: Runs more solid than before with more power in higher rpms and up hills.
