foxracer45 Posted March 18, 2008 Share Posted March 18, 2008 I have a 86 subaru gl sedan 5 speed, and it has a lot of slack, side to side movement in the shifter, how can i fix this? Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted March 18, 2008 Share Posted March 18, 2008 I have a 86 subaru gl sedan 5 speed, and it has a lot of slack, side to side movement in the shifter, how can i fix this? Requires either crawling under the car or taking the shifter boot off and looking at the bushings. They probably need replacing or if you're lucky, something is loose. Also, welcome to the board. Link to comment Share on other sites More sharing options...
ivantruckman Posted March 18, 2008 Share Posted March 18, 2008 the rubber block can come loose from its mount too, you can use some good zip ties and some epoxy, works great. ill try to get some pics tomorrow when i get back to the shop Link to comment Share on other sites More sharing options...
foxracer45 Posted March 19, 2008 Author Share Posted March 19, 2008 Well that rubber block did come loose but i already fix it! could there be something in the linkage out? Link to comment Share on other sites More sharing options...
