4wheeln22 Posted March 20, 2008 Share Posted March 20, 2008 My wife's 04 obw has just had its first code. it is the p0483 cooling fan rationality check. Any advice on what to look for? How about a trick to get the relays out of the clips they are in? (two screwdrivers??) this car only has 52k on it btw. is this a warranty-covered issue? thanks for the attention . Pat Link to comment Share on other sites More sharing options...
beataru Posted March 20, 2008 Share Posted March 20, 2008 Well, First do the Fans cycle on? Check for some loose connections and 2 screwdrivers should work to get those clips out, Im asuming that the clips are those black wrap around ones with the 2 wedges that stick through the metal? Link to comment Share on other sites More sharing options...
