4x4 idea of the day.
bigo1966
Someone should put a 4.44 rear diff in the rear and run 33" tires in the back and have the 3.9 in the front and 29's.
Do that and let me know how it works out.
I think it would look pretty sick on the buggy but i dont have a 4.44 rear diff.
Orion
I just can't see the benifit if you still havelow clearence in the front where its worst anyhow.
Maybe one or two inchs extra in the front and then use the ability the rear DOJ's and no steering get you to crank those shafts.. but I'd just run larger tyres on the rear as well.
I agree there wouldn’t be too much of a benefit. Possibly look like something out of Mad Max and still work in 4x4 would be the perk. I could only imagine the amount of ground clearance back there:headbang: .
You could do this with an open center with no problems.. but then who wants to run an open center.
A local guy here is running a 3.90 OBS 5spd transmission with a 4.44 rear diff. The 5spd has an open center so it wont FUBAR anything and with the different FD ratios he ends up with about a 41f/59r power split. good for pavement.
He's cooking his center VLSD as we speak.
Even if it was an open diff it would still be taking a hell of a beating. Although diffs are made to differentiate they aren't ment to do it all the time. Spider gears will wear then break teeth off. If it is like every other EJ AWD trans I know of then it will have the VLSD and by now its probably cooked and not doing VLSD action anymore.
OBS = Outback Sports I believe
