Hot/Cold Resistance of ECU Coolant Temp Sensor?
(ed note posted 2 days later) :)' UH WAIT, WAIT. It's the "air bypass" solenoid I unplugged. I couldn't see in the dark. Totally different issue. Still runs much better with it unplugged. Totally different issue,
I hope this gets buried. Thanks NIpper, I saw the charat in the Haynes. Thats plug on the temp sensor is impossible to get to. Cracked some small hoses trying.
Slinking away hoping not to be noticed.
(end ed.)
I think I want to play around with the collant temp sensor feedback to the ECU.
I read that that a cold CTSensor has 2.8k ohms. Does anyone know what the hot is supposed to be?
If I put a fairly large reisistor in parallel with the circuit, it will lower the cold resistance proportionally more than it lowers the hot resistance, kind of compressing the curve. Would this lean out the cold mix?
The 97 2.2 Legato 153k runs too rich when cold, but perfectly when warm, except for a kind of hard idle.
I've checked all other things. My feeling is that at this engine at 153k has lowered compresssion and doesn't need all that gas when cold. I assume the cold start mix is a baseline and not mixed from the MAF, because there is no air flow when stopped.
Anybody have a done deal to share on this?
(ed note
mpergielelmhurstil97legato99forester
212F 176 ohms
194 240
176 332
158 458
140 668
122 672
112 1182
104 1458
95 1800
86 2238
76 2795
68 3520
58 4450
50 5670
40 7280
32 6420
28 move to florida.
Har. Thanks much. I can work from there.
(ed.: next day) This morning it was snowing (about 32F) so I decided to take the Legato and didn't want to smell that rich gas at all so I put a jumper across the Coolantempsensor and it started and ran great, idled easily (used to rumble). At the first stop, it threw a CEL, so more fix is required.
I charted the numbers and got a curve, so I think I may be able to tune this with that parallel resistor, but first I have to measure the sensor hot, when I get home, and the last thing I want to do immediately is dig under a hot hood.
Get the book and find out
(yes they are, my oops)
nipper
