mkoch Posted March 21, 2008 Share Posted March 21, 2008 I just had a 1984 GL Wagon 4wd delivered to me. The key can be removed with the ignition still on. I thing the shipper left the ignition on while the car was being transported. It may have been left on for four days. The battery now will not take a charge from a plug-in charger, 6 amp. The starter relay clicks after about 1/8 turn on the engine. Maybe the coil, or the Electronic Control Unit were damaged? I'd like to know what might not be o.k. now. mkoch Link to comment Share on other sites More sharing options...
suberdave Posted March 21, 2008 Share Posted March 21, 2008 put a new battery in it... everything should be just fine. but it sounds like the batt is shot. -=Suberdave=- http://www.suberdave.com Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 21, 2008 Share Posted March 21, 2008 If you get the right charger on that battery, it should be able to blast the sulfate off the plates and bring it back. 6 amp isn't going to do it though - most of the decent high amp chargers are around 100 amps or so. Quick fix is to buy a new battery of course. There won't be any damage beyond that. GD Link to comment Share on other sites More sharing options...
Durania Posted March 21, 2008 Share Posted March 21, 2008 Don't feel bad about being able to remove the key. My Brat is like that and its great on cold mornings, cause I can go out and start it and go back in my apartment to wait. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 21, 2008 Share Posted March 21, 2008 That's common with worn out keys. If you have a new key ground from the passenger door lock code it probably won't come out like that on it's own. My hatch does it too, and the worn out key is annoying and barely works. GD Link to comment Share on other sites More sharing options...
Turbone Posted March 21, 2008 Share Posted March 21, 2008 I dont know. My RX is nice and tight and my SVX can fall out (same with the Hatch). The springs might be wore out on the cams inside the switch. Link to comment Share on other sites More sharing options...
baccaruda Posted March 21, 2008 Share Posted March 21, 2008 depends on how heavy the PO's keychain was. If they were a collector your cylinder is shot. Link to comment Share on other sites More sharing options...
misledxcracker Posted March 21, 2008 Share Posted March 21, 2008 Mine doesnt come out, but it's really loose. It'll fall out one of these days. +1 on the heavy keychain ruining the cylinder as for the battery, i'd say replace it. mind as well, if it's a long term vehicle. Link to comment Share on other sites More sharing options...
Stevethefolkie Posted March 21, 2008 Share Posted March 21, 2008 if you're not going to replace the battery at least pop the caps and make sure there's water in it before you try to charge it - Link to comment Share on other sites More sharing options...
ivantruckman Posted March 21, 2008 Share Posted March 21, 2008 if the battery is discharged it could be frozen, try to bring it indoors, in Mi we have been just below frezing, do know about Mo Link to comment Share on other sites More sharing options...
