subiemech85 Posted December 23, 2003 Share Posted December 23, 2003 need to know part# for seal kit What's mickey mouse got pic? ea82 Quote Link to comment Share on other sites More sharing options...
Erik R Posted December 23, 2003 Share Posted December 23, 2003 Hey, I just intalled a seal set in my oil pump (EA82 non-turbo). Maybe I can still pull the packages out of the waste bin and get the #'s for ya........Local Soob dealer had all in stock, though not actually sold as a set. "mickey-mouse" gasket looks like it sounds......and is imperative to good oil pump function. Kind of pear shaped with two "ears" on one side......to seal the inlet and outlet from the oil filter (I think?) Quote Link to comment Share on other sites More sharing options...
Flow Posted December 23, 2003 Share Posted December 23, 2003 I bought a aftermarket kit from shucks for 15$ I think. 2 o-rings (ones called a micky mouse because of the way it looks) and the shaft seal. Pkgd by Beck/Arney-- part # 039-6320 Dusty 86 4x4 wagon Quote Link to comment Share on other sites More sharing options...
tailgatewagon Posted December 23, 2003 Share Posted December 23, 2003 micky ea82/ea82t, 15066AA000 oil pump impeller(the round one that gos next next to micky 806945020 and the oil pump front main seal. 806718090 you need all three if your going to reseal the oil pump. while your in there front main seal motor 806738070 cam seals 806738040(from memory so check with dealer) ps i can beat the dealer prices with free shipping. Quote Link to comment Share on other sites More sharing options...
djbroadus Posted December 30, 2003 Share Posted December 30, 2003 What about EA81 I need to get it for my hatch? Serial number, name? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 30, 2003 Share Posted December 30, 2003 i just went to napa and ordered, but i dont remember the numbers. but i looked them up myself and write them down there. try the parts #'s link on my subaru webpage, straight from the genuine parts guide Quote Link to comment Share on other sites More sharing options...
Partsman Posted December 30, 2003 Share Posted December 30, 2003 Mickey Mouse is NAPA/Victor # B45702 Pump seal is NAPA/CR #7205 For the other O-ring, all I see is the kit mentioned earlier by Flow that has it all - Beck-Arnley #039-6320 - NAPA sells as well. If you want to do the crank and cam seals, the best seals NAPA sells are in the timing cover gasket set NAPA/Victor JV-1028 - it also has the rubber timing cover gaskets, the oil pump seal, and a couple of thin seals I can't identify Quote Link to comment Share on other sites More sharing options...
mickytrus Posted March 30, 2004 Share Posted March 30, 2004 Hi T-wag, T-wag your priv email is full............... Are you still selling gaskets and seals? Wondering about cambox o-rings...... the mating surface (head to cambox)... and what about the three seals for a oil pump.... I am wonder where the third seal goes....... mickeymouse, ok know where that goes........ the impeller one, ok know where that goes...... It is the other one I forget what it was called...... appreciate some feed back Thanks, Micky Quote Link to comment Share on other sites More sharing options...
The Scooby Posted March 30, 2004 Share Posted March 30, 2004 i got a kit for the 3 seals that you need, its $20 plus shipping, it has the one O-ring, micky mouse gasket, and the seal for the drive shaft on the oil pump. Shean Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 31, 2006 Share Posted December 31, 2006 Hi T-wag, I am wonder where the third seal goes....... mickeymouse, ok know where that goes........ the impeller one, ok know where that goes...... It is the other one I forget what it was called...... appreciate some feed back Thanks, Micky The third seal is the shaft seal or "main". You have to remove the TB pulley from the front of the pump. You can use a cut open piece of rubber hose to pad the jaws of some channel locks or a vise to hold the pump rotor still and then loosen the nut that holds the pulley on. Don't nick or ding the pump rotor! Quote Link to comment Share on other sites More sharing options...
GBANGER Posted March 29, 2008 Share Posted March 29, 2008 i got a kit for the 3 seals that you need, its $20 plus shipping, it has the one O-ring, micky mouse gasket, and the seal for the drive shaft on the oil pump. Shean do you still have that kit?? I want the three seals you speak of. Cheers G Quote Link to comment Share on other sites More sharing options...
