oil pump seals
Hey, I just intalled a seal set in my oil pump (EA82 non-turbo).
Maybe I can still pull the packages out of the waste bin and get the #'s for ya........Local Soob dealer had all in stock, though not actually sold as a set.
"mickey-mouse" gasket looks like it sounds......and is imperative to good oil pump function. Kind of pear shaped with two "ears" on one side......to seal the inlet and outlet from the oil filter (I think?)
micky ea82/ea82t,
15066AA000
oil pump impeller(the round one that gos next next to micky
806945020
and the oil pump front main seal.
806718090
you need all three if your going to reseal the oil pump.
while your in there
front main seal motor 806738070
cam seals 806738040(from memory so check with dealer)
ps i can beat the dealer prices with free shipping.
Mickey Mouse is NAPA/Victor # B45702
Pump seal is NAPA/CR #7205
For the other O-ring, all I see is the kit mentioned earlier by Flow that has it all - Beck-Arnley #039-6320 - NAPA sells as well.
If you want to do the crank and cam seals, the best seals NAPA sells are in the timing cover gasket set NAPA/Victor JV-1028 - it also has the rubber timing cover gaskets, the oil pump seal, and a couple of thin seals I can't identify :rolleyes:
  • 3 months later...
Hi T-wag,
T-wag your priv email is full...............
Are you still selling gaskets and seals?
Wondering about cambox o-rings......
the mating surface (head to cambox)...
and what about the three seals for a oil pump.... I am wonder where the third seal
goes....... mickeymouse, ok know where that goes........ the impeller one, ok know where that goes...... It is the other one
I forget what it was called......
appreciate some feed back
Thanks, Micky
  • 2 years later...
  mickytrus said:
Hi T-wag,
Thanks, Micky
The third seal is the shaft seal or "main". You have to remove the TB pulley from the front of the pump. You can use a cut open piece of rubber hose to pad the jaws of some channel locks or a vise to hold the pump rotor still and then loosen the nut that holds the pulley on. Don't nick or ding the pump rotor!
  • 1 year later...
  The Scooby said:
i got a kit for the 3 seals that you need, its $20 plus shipping, it has the one O-ring, micky mouse gasket, and the seal for the drive shaft on the oil pump.
Shean
do you still have that kit?? I want the three seals you speak of.
Cheers G
