anybody no how to reset them,
Look at http://endwrench.com/images/pdfs/ABS.pdf and identify the ABS system - it's probably ABS 5.3. If so, try to find the diagnostic connector (B82, 6-pin, black color) and the two ground probes, usually taped to the harness in the lower dash area above the brake pedal. If you get that far, the PDF tells how to reset the ABS ECU. If the instructions aren't clear (such as pin numbering), someone can probably post a diagram.
jamie, just so you know
i replaced the ring and sensor on driverside, myself
i do ALL my own work
and the fluid level was good, i did also replace all 4 rotors and pads
and then bleed the whole thing
untill it bleed clear at all 4 corners
i also rebuilt the 2.5l , rebuilt the 4eat becouse the 4wd was chunked
new header and cats, new o2's, new cluster, speed sensor
stil has an issue with the speedo
that is a different post though
