scrounge Posted March 22, 2008 Share Posted March 22, 2008 This is an 87 GL 4wd wagon with the overhead cam 1.8 motor. I'm in the midst of pulling my engine to replace a clutch. How hard is it to separate the engine from the transmission? I'm having a bear of a time. I only want to shift it forward to get to the clutch, but the engine and transmission won't separate. I count 2 bolt and two nuts to remove? Is it normal to have the two lower studs bind? That appears to be the trouble. The top pulls free pretty handily but the bottom doesn't like to budge. It also looks like I will need to remove the power steering hoses, but I'm hoping to leave the AC compressor where it's at since there seems to be enough slack in the lines. The motor mounts are clear of the engine cradle. I've pulled my fair share of vintage Oldsmobile Rocket V8s, so I'm not completely new to this, but the little soob is tenacious. Any suggestions are appreciated, thanks. Link to comment Share on other sites More sharing options...
Gloyale Posted March 22, 2008 Share Posted March 22, 2008 2 bolts and 2 studs is correct. You just need a bit of leverage. Use a pry bar carefully between the 2 sections. As for the power steering. Unbolt the pulley from the pump, then unbolt the pump from it's bracket. Undo the 2 10mm bolt that secure the line ot the engine, and now fold the whole unit and line out of the way while removing the engine. Link to comment Share on other sites More sharing options...
Turbone Posted March 22, 2008 Share Posted March 22, 2008 Theres 2 more nuts on studs on the bottom. There should be a total of 4. If you have a jack of some sort, put it under the tranny to lift it a little. Link to comment Share on other sites More sharing options...
Gloyale Posted March 22, 2008 Share Posted March 22, 2008 Turbone said: Theres 2 more nuts on studs on the bottom. There should be a total of 4. I think that's the 2 nuts he referred too. I presumed the 2 bolts mentioned included the nuts on their ends. Link to comment Share on other sites More sharing options...
Turbone Posted March 22, 2008 Share Posted March 22, 2008 Yeah, I didnt catch it the first time. I've had to get pretty agressive with them before. Shake, jerk, cuss, whatever it takes. Link to comment Share on other sites More sharing options...
scrounge Posted March 22, 2008 Author Share Posted March 22, 2008 Gloyale said: I think that's the 2 nuts he referred too. I presumed the 2 bolts mentioned included the nuts on their ends. That sounds right. In short, there's 4 fasteners holding the engine to the transmission? I've tried wiggling the tranny up and down with a jack, I still have trouble. I don't like prying too hard on the cast aluminum, maybe I need to give it a little more grunt. I'll remove the power steering pump, that may help some. Thanks. Link to comment Share on other sites More sharing options...
Gyoas759 Posted March 22, 2008 Share Posted March 22, 2008 I hesitate to use a hammer/pry bar to get it started. In the past I've wrapped marine rope or a tow strap around the front of the engine, then lift the whole engine up and let it bounce down. Another guy helping you yank it from side to side works too. A few hard jolts like that are usually enough to break the seal. Then a pry bar or a big screwdriver can get you the rest of the way. Link to comment Share on other sites More sharing options...
desertsubaru Posted March 22, 2008 Share Posted March 22, 2008 Did you remove the exhaust from the heads? Link to comment Share on other sites More sharing options...
crazyhorse001 Posted March 22, 2008 Share Posted March 22, 2008 I just had this prob on an EJ, today as a matter of fact. I hammered in a brass putty knife to get it started, then progressively larger screwdrivers, until I could get a tire iron in & pry them apart. In my case, the dowel pins had rusted. Link to comment Share on other sites More sharing options...
Subaru_dude Posted March 22, 2008 Share Posted March 22, 2008 I've had trouble with this too, mine was rusted pretty badly and it took me and my dad going insane and jerking the engine as hard as we could to get it loose. Even then it took everything we had and 2-3 hours of repetative insanity. The cast aluminum should be okay as long as you don't hit it with a sledge like I did. I broke a pry-bar clean in 2 without doing a whole lot of damage to the aluminum bell housing, so you should be okay with getting pretty agressive with it. Link to comment Share on other sites More sharing options...
Nug Posted March 22, 2008 Share Posted March 22, 2008 Take a punch and smack the two alignment dowels in the bellhousing. They corrode and hold it all together. Link to comment Share on other sites More sharing options...
scrounge Posted March 22, 2008 Author Share Posted March 22, 2008 I have a 1/8 inch crack between the engine and transmission at the top, and just a tiny little bit at the bottom. (The exhaust is removed from the car, so it's not in the way.) I think I have it started, I just expected things to slide apart more smoothly once the seal is broken. I'm used to popping the motor free and hauling away. Thanks. Link to comment Share on other sites More sharing options...
Gloyale Posted March 22, 2008 Share Posted March 22, 2008 scrounge said: I have a 1/8 inch crack between the engine and transmission at the top, and just a tiny little bit at the bottom. (The exhaust is removed from the car, so it's not in the way.) I think I have it started, I just expected things to slide apart more smoothly once the seal is broken. I'm used to popping the motor free and hauling away. Thanks. You're probably used to Cast iron blocks. Alloy block + steel dowels = corroded dowels Link to comment Share on other sites More sharing options...
Sonicfrog Posted March 23, 2008 Share Posted March 23, 2008 scrounge said: That sounds right. In short, there's 4 fasteners holding the engine to the transmission? I've tried wiggling the tranny up and down with a jack, I still have trouble. I don't like prying too hard on the cast aluminum, maybe I need to give it a little more grunt. I'll remove the power steering pump, that may help some. Thanks. I would say five counting the starter bolts. Link to comment Share on other sites More sharing options...
Gloyale Posted March 23, 2008 Share Posted March 23, 2008 Sonicfrog said: I would say five counting the starter bolts. The lower starter bolt is actually a stud, mounted to the trans bellhouing. It does not connect to the engine at all. The starter and that lower nut DO NOT need to be removed. Starter stay bolted in place to the trans by the lower stud. Link to comment Share on other sites More sharing options...
carfreak85 Posted March 23, 2008 Share Posted March 23, 2008 Did you disconnect the engine mounts? Link to comment Share on other sites More sharing options...
jonas Posted March 23, 2008 Share Posted March 23, 2008 i suggest beer. Link to comment Share on other sites More sharing options...
crazyhorse001 Posted March 23, 2008 Share Posted March 23, 2008 jonas said: i suggest lots of beer. Fixed your post Link to comment Share on other sites More sharing options...
jonas Posted March 23, 2008 Share Posted March 23, 2008 crazyhorse001 said: Fixed your post Link to comment Share on other sites More sharing options...
scrounge Posted March 24, 2008 Author Share Posted March 24, 2008 The engine was out by Saturday afternoon. It just needed more persuasion. Installed the clutch kit, and moved on to timing belts, cam seals, tensioners and an idler. Waiting for the last of the parts to come in tomorrow. Thanks for the helpful suggestions. Link to comment Share on other sites More sharing options...
