SakoTGrimes Posted March 23, 2008 Share Posted March 23, 2008 When I stop, oil drips from the right side pipe right under the engine, and smoke billows out from under the hood. I lost an entire quart today already. What the heck is going on? EA71 Link to comment Share on other sites More sharing options...
maudsland Posted March 23, 2008 Share Posted March 23, 2008 Well you guessed it you have an oil leak, where from, could be from a few places, my guess would be the front oil seal or maybe the rocker covers, but anywhere, as for the smoke, the oil is just leaking onto the exhaust. to find the leak clean down the engine till no traces of oil then start the car and see where it is coming from. Thierry Link to comment Share on other sites More sharing options...
SakoTGrimes Posted March 26, 2008 Author Share Posted March 26, 2008 So I just now got underneath the car and took off the exhaust shield thingy which allowed me to see that there was a really clean area (from a flow of oil moving over it) right in the middle of the block and head. So I guess that means it's a headgasket? And, since I've never changed one before, please tell me - do valves and springs and crap fall out when you unbolt a head or do they stay put? Link to comment Share on other sites More sharing options...
Subieguy Posted March 26, 2008 Share Posted March 26, 2008 No they stay put. Link to comment Share on other sites More sharing options...
SakoTGrimes Posted March 26, 2008 Author Share Posted March 26, 2008 Subieguy said: No they stay put. This information pleases me. Things flying apart really ruins a day. So, can I just simply take the head off, put a new headgasket in and bolt it back on? Even I could do that. Link to comment Share on other sites More sharing options...
75skunkaroo Posted March 28, 2008 Share Posted March 28, 2008 not quite that easy, but yeah. you should just sell me your brat for the last $20 i have :cool: -mike Link to comment Share on other sites More sharing options...
ls650v Posted March 28, 2008 Share Posted March 28, 2008 Correct me if I'm wrong, but I think you have to pull the engine. There doesn't seem to be enough clearance (on my 78) to clear the frame. Also, you need to be careful when installing the head to make sure the intake manifold mating surface is parallel with the mating surface on the other head to insure a good seal (there is some slop) when reinstalling the intake manifold. When removing the head be prepared for the head to hang up on crud on the mounting studs or the intake manifold bolts to snap. I would go with a premium quality head gasket that does not require a retorque. Link to comment Share on other sites More sharing options...
