Toyota questions...
[HTi]Johnson
I know nothing about toyotas...do they have rear ends where the ratio is 3.9?
You gotta be a bit more specific. I know 1973 Toyota Corollas with a 1.6L engine had 3.90 gears in the back, the ones with the 1.2L engine had 4.10 gears.
When you go to the dealer to do your research, you will find, that there are so many different Toyota rear axles, with different ratios that your head will spin.
Exactly what I meant. (Knowing nothing about Toyotas)
I want a solid axle with 3.9 ratio.
the majority of the truck axles come stock with 4.10 diffs. if you swap a legacy diff up front and a transfercase in, you could use the stock truck axles.
as for the toyota rear diffs from the trucks, all you need to know.... it appears 8" diffs come in 4.10 and up, 7.5" toy diffs came in 3.9. options with an 8" rear diff are innumerable, i'm not sure about lockers and such for the 7.5" diff
info from the http://www.pirate4x4.com/forum toyota FAQ... don't bother asking any questions over there unless you have thick skin...
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
Differentials – Gearing
Gearing..... with a 4 banger and single case
stock 4.10= 31 or smaller tire
4.88=33 inch tire
5.29= 35 to 38 inch tire.
5.71= NOT RECOMMENDED FOR REAL OFFROAD USE
Originally posted by DSI
83-older 4.11 diff's are 37/9 and are 8in 4cyl style diff's, in 84 they switched th the 41/10 ratio, any time you have more teeth to a pinion the stronger the diff will be, reason being: more tooth contact/more teeth contacting the ring gear at one time.
This is the same reason 5.71's are very weak, 6 teeth, 5.29's have 7, 4.88's and 4.38's have 8, 4.56's have 9 and 411's have 9, 410's have 10, and 390's have 10
Originally posted by TNToy
If you have the axle code of your vehicle, it is easy to find out what size differential, what ratio, and what pinion set-up you have. This will also help if you are hunting for a particular unit off another vehicle. The axle code is in the vehicle ID plate under the hood or drivers door. The axle code is 4 digits: a letter followed by 3 numbers.
Example: G292 = 8.0" 4.10 final ratio 2 pinion
Code:
1ST R&P SIZE 2nd/3rd R&P RATIO 4th DIGIT PINION SET-UP
F = 7.5" 07 = 3.900 2 = 2 pinion
G = 8.0" 08 = 4.110 3 = 2 pinion LSD
10 = 4.375 4 = 4 pinion
14 = 4.875 5 = 4 pinion LSD
25 = 4.556
28 = 4.300
29 = 4.100
31 = 3.91
38 = 3.42
43 = 3.56
54 = 3.90
66 = 3.07
Code:
Ratio Ring/Pinion Color Crawl:Ratio
3.42 ...42/12... Purple ...31:1
3.90 ...39/10... Red... ...36:1
4.10 ...41/10... Pink.. ...37:1
4.11 ...37/09... Orange ...37:1
4.30 ...43/10... Blue.. ...39:1
4.37 ...35/08... Green. ...40:1
4.56 ...41/09... Yellow ...41:1
4.88 ...39/08... White. ...44:1
5.29 ...37/07... None.. ...48:1
5.71 ...40/07... None.. ...51:1
Differentials – Info
General Toy diff info including identification with pictures.
http://home.4x4wire.com/erik/diffs
"LPH" (Long Pinion Head) vs "SPH" (Short Pinion Head). by Drew Persson
http://www.pirate4x4.com/forum/showt...23#post1478223
Myth Settled: 8.4, V6, 4cyl, ALL 8" - by Brian Ellinger
http://www.pirate4x4.com/forum/showt...hreadid=228681
Pluging ABS sensor hole in late model diffs
http://www.pirate4x4.com/forum/showthread.php?t=587522
Differential picture identification by 4RnrRick
Toyota 2 pinoin 4 cylinder 7 1/2" diff (27 spline) used on 2wd and some celicas
http://tellico.off-road.com/wwwthrea...750_driver.jpg
Toyota 2 pinoin 4 cylinder 8" diff (30 spline)
http://www.4crawler.com/4x4/Images/Diff4Cyl.jpg
Toyota 4 pinoin 6 cylinder 8" diff (30 spline)
http://www.4crawler.com/4x4/Images/Diff6cyl.jpg
Toyota Land cruiser high pinion 8" diff (30 spline)
http://www.4crawler.com/4x4/Images/DiffHP.jpg
Toyota 4 pinion 6 cylinder 8" 3rd from a '96-00? 4Runner (30 spline)
http://www.pirate4x4.com/forum/attac...&postid=436184{broken}
Toyota 8.25 or 8.4 diff Taco / T-100 / Tundra (30 spline)
http://tellico.off-road.com/wwwthrea...100_tundra.jpg
Differential Mounting Differences Between Different 3rd Members
http://www.pirate4x4.com/forum/showt...52#post5331552
Differential - Shaved, Trussed, and Armored Axle Collection
http://www.pirate4x4.com/forum/showthread.php?t=456309 by TheBandit
http://www.pirate4x4.com/forum/showthread.php?t=228464
http://www.pirate4x4.com/forum/showthread.php?t=154306
http://www.pirate4x4.com/forum/showthread.php?t=93356
Differential Stud Upgrades - BEEF!!
http://www.pirate4x4.com/forum/showthread.php?t=485834
http://www.pirate4x4.com/forum/showthread.php?t=490532
  • 2 months later...
driving or building you sink way to much money way to quick
soob or nonsoob you'll sink a lot of money. it's the nature of the beast, and the money has to get forked up to 4wheel hard. :rolleyes: i don't think i'm even near what i've sunk into the subaru in the toyota yet. it's fairly close though. the subaru has over the years well over $7k. the cost to strength ratio though...
oh to only have have have 7k invested in my toy would be awsome i'm over twice that and still can't wheel it. i hate projects altogether. i never know when to say enough.
that's a very conservative estimate, and doesn't include the multitude of tires, consumables (ie replaced axles and stubs, trannies, differentials) or repairs over the years. just the straight to what it is cost. otherwise i'd be sitting here for days trying to run it all up. projects eat money, but in the end they can be worth it.
  • 5 months later...
info from the www.pirate4x4.com/forum toyota FAQ... don't bother asking any questions over there unless you have thick skin...
4.88=33 inch tire
Code:
25 = 4.556
28 = 4.300
29 = 4.100
31 = 3.91
38 = 3.42
43 = 3.56
54 = 3.90
66 = 3.07
Code:
Ok I found a stock Tacoma rearend from a v-6 , what gear ratio is it ?? would it be 4.11 ??
also I Have a older style toyota rearend which is narrower , will the "punkin" from the taco fit into the older housing ??
