crazyhorse001 Posted March 25, 2008 Share Posted March 25, 2008 Engine: EJ22 ~120k mi I cannot get the dadgummit water pump to seal! I've tried "right stuff" and black RTV, Cleaning well between attempts. Is there any secret handshake mojo I'm missing? The car is running SOOOOO sweet otherwise! (& getting about 5mpg better to boot) Quote Link to comment Share on other sites More sharing options...
njdrsubaru Posted March 25, 2008 Share Posted March 25, 2008 use subaru gasket only! i've done many timing belts and water pump replacements and everytime i used something other than a gasket by subaru it always leaked. try advance auto parts, autozone or napa they should have aftermarket gaskets Quote Link to comment Share on other sites More sharing options...
aircraft engineer Posted March 25, 2008 Share Posted March 25, 2008 The flat steel gasket seemed to seal well when I put it in (no sealant additional whatever) You might try the anaerobic permatex - it is supposed to bridge up to .010 gaps (just let it sit for a couple of hours before refilling the coolant) it will be a bit difficult to take off later, though. IF I wanted to do it that way, I would coat both sides of the steel gasket with a thin layer and bolt it down - that would probably help with later disassembly Quote Link to comment Share on other sites More sharing options...
Reveeen Posted March 25, 2008 Share Posted March 25, 2008 My Legacy came to me with a leaking water pump, and because it is a turbo model it was an order and wait. I disassembled the thing only to find, that the "person" in there before me stripped out 4 of the mounting holes, when they installed a new pump. After fixing the "bad" holes in the block, taking no chances, I installed the new pump and raised flange OEM gasket (the gaskets are a crush fit 1 time use only). When working on Simca cars in Europe they had (Simca) a magic blue goop, that I have yet to find a N. American substitute for, designed specifically for alloy engine assemblies. I am not adverse, and did use Permatex #3, on my water pump, just in case. http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_sealants/auto_Permatex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm While in there, I did replace all those small water lines connected to the water pump, again, taking no chances. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted March 26, 2008 Share Posted March 26, 2008 Yes I think the secret is the one time use only metal gasket from Subaru. It requires no additional sealant and seems to work very well. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted April 16, 2008 Author Share Posted April 16, 2008 Ok, 3 new gaskets later, I STILL can't get the water pump to seal. I've tried with sealer, without sealer, anerobic sealer, paper gaskets, you name it. All of my bolts tighten equally, so that's not an issue. I don't see any cracks on the 2 pumps I have, nor the block. Not saying there aren't any, just saying I can't see them. HELP ME! before I set fire to this car! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 16, 2008 Share Posted April 16, 2008 what engine? is the water pump the correct one? i'd compare it to another, maybe it's wrong or defective? aftermarket or Subaru pump? did you try the OEM Subaru gasket without sealer? water pumps seem to seal rather easily without sealant, if it's not sealing with it i have to imagine something is really out of whack. i'd want to compare it against another pump or just install another...but i hate to tell you that? i can send you a used pump that is known good if you want paul, just shoot me a note. check the surface of the pump/block for flatness at the mating surface. good luck - sounds like a real pain?! Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted April 16, 2008 Author Share Posted April 16, 2008 The engine is an ej22, the pump is an ej25, that MAY be my problem. I installed the pump from my EJ25, as it had less than 1k miles on it. I was told when I got the engine, that the W/P was bad. Curiously, there was black RTV all around the pump, as if it was leaking before. Could there be unseen cracks in the block? If so, can I find them without removing the engine? Quote Link to comment Share on other sites More sharing options...
nipper Posted April 16, 2008 Share Posted April 16, 2008 Now its time to look at the sealing surface. Take out a straight edge and make sure its flat. Next snug the bolts by hand, then using a star pattern, tighten them one turn at a time. Get out a torque wrench and tighten them to the proper torque, one at a time, one turn at a time. nipper Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted April 16, 2008 Author Share Posted April 16, 2008 I checked the sealing surface for flatness, it APPEARS flat, but getting to it, with the engine in, is a bit of a pain. As for tightening, I've been using a 6lug wheel tightenig pattern. I haven't yet broken out the torque wrench, but I will. So the water pumps are a common part # on the EJ22-25's? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted April 16, 2008 Share Posted April 16, 2008 The water pumps afiak are interchangeable (fit wise; maybe not spec wise though); one of them I think is called a 'high velocity' type. There is the stamped impeller and the cast impeller. There are a few threads comparing the two. Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted April 16, 2008 Share Posted April 16, 2008 I used the Subaru OEM metal/rubber gasket and a 16 dollar waterpump Ebay style. I did coat the gasket with sticky tac (waterpump side only then placed it onto the waterpump. I then mounted the waterpump to the block. Quote Link to comment Share on other sites More sharing options...
