86subaru Posted December 24, 2003 Share Posted December 24, 2003 yes i already did a search , what would cause the wipers to move slowly or not work on hi speed ? last night i sprayed around the wiper plug and got the wipers to move faster and even the hi speed ,but no hi speed today and slow on low ? Link to comment Share on other sites More sharing options...
subiemech85 Posted December 24, 2003 Share Posted December 24, 2003 did you remove the plastic boot, then lube? check voltage, connections Link to comment Share on other sites More sharing options...
86subaru Posted December 24, 2003 Author Share Posted December 24, 2003 i removed the boot and lubed but did not ck voltage the connections looked good ,and it worked good hi and slow Link to comment Share on other sites More sharing options...
86subaru Posted December 24, 2003 Author Share Posted December 24, 2003 but even the back wiper moved slower , would this mean my alt is going bad ? or the connections around it might be loose Link to comment Share on other sites More sharing options...
subiemech85 Posted December 24, 2003 Share Posted December 24, 2003 14+ volts makes them fly 10- volts makes them slow Link to comment Share on other sites More sharing options...
Forkspear Posted December 25, 2003 Share Posted December 25, 2003 I ran a jumper wire from the black ground wire on the wiper motor to a bolt on the strut tower. Worked fine until I had to use the jumper wire to make the engine run. Link to comment Share on other sites More sharing options...
86subaru Posted December 25, 2003 Author Share Posted December 25, 2003 ok will ck it out friday , and try somethings ,thanks agin Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 25, 2003 Share Posted December 25, 2003 was the battery cold. mine will creap when the battery is still cold. battreies don't perform as well when cold. as i'm sure you know just a thought Link to comment Share on other sites More sharing options...
torxxx Posted December 25, 2003 Share Posted December 25, 2003 take the wiper motor out and clean the contacts and brushes in the motor. Mine were really slow this summer and I did that and the problem was fixed. Link to comment Share on other sites More sharing options...
Qman Posted December 26, 2003 Share Posted December 26, 2003 Are they slow at idle and at higher RPM's? Link to comment Share on other sites More sharing options...
86subaru Posted December 26, 2003 Author Share Posted December 26, 2003 yes it was cold outside [ 25] move slow at idle , i sprayed around the wiper motor and they took off great even the hi speed , but the next day no hi speed and moving slowly again Link to comment Share on other sites More sharing options...
Qman Posted December 26, 2003 Share Posted December 26, 2003 move slow at idle Does it act normally at higher RPM's? Link to comment Share on other sites More sharing options...
86subaru Posted December 26, 2003 Author Share Posted December 26, 2003 well at hi rpns not really , my 88 gl 4wd manual wagon the wipers really work great with 180,000 mi , so i am thinking that i sprayed one of the wires and which ever one that is is either broken or crap on it , but today i will find the problem Link to comment Share on other sites More sharing options...
Qman Posted December 26, 2003 Share Posted December 26, 2003 Sorry to keep asking the same questions. But, if it was performing well at driving RPM's then I would say check the connections at the battery and alternator. But you say it is not. What are you using to clean/spray the wiper motor with? You may have some bad solder developing. You may need to scrape and clean or even resolder. Do you have access to another wiper motor? If you do you may want to test it in the system to take the system out of the equation. Good luck! Link to comment Share on other sites More sharing options...
86subaru Posted December 26, 2003 Author Share Posted December 26, 2003 yes i have another wiper motor, silocone spray , but i will look at it alittle closer or run a ground wire to the struts from the wiper ground , but what about the back ? .will check back and let everyone know what i found out , thanks Link to comment Share on other sites More sharing options...
Qman Posted December 26, 2003 Share Posted December 26, 2003 Have you done a voltage check at the alternator and battery? It may still be charging system related. Link to comment Share on other sites More sharing options...
86subaru Posted December 26, 2003 Author Share Posted December 26, 2003 no , can autozone do this ? because i checked out today still no hi speed Link to comment Share on other sites More sharing options...
86subaru Posted December 26, 2003 Author Share Posted December 26, 2003 here is something strange, went to the bank and the hi speed works good, but just 1hr before they did not ? but the car was sitting ,, and when i went to the bank of course i was moving Link to comment Share on other sites More sharing options...
86subaru Posted December 27, 2003 Author Share Posted December 27, 2003 i went to get gas up the road 5mi , the hi speed of the wipers do not work again , but a few hrs ago when i washed the car they were fine:confused: Link to comment Share on other sites More sharing options...
Skip Posted December 27, 2003 Share Posted December 27, 2003 Jim, I talked to my brother Mo about this, he called his brother Ron He said pull the connector on the wiper moter apart?? Drive to Uncle Charlie's waffle house and plug the connector back togeather. Try the way hi speed wipers. If that does not fix it, he told me my cousin Id had this problem, He consulted my unkle Iot. He said loosen the screw holding the ground wire on the cover of the wiper motor. Wash the dash board then retighten the screw?? I don't know anything about those things but this is the way my family fixed it Hope this wipes the smile off your face J/K Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2003 Share Posted December 27, 2003 Skip - you rock! :lol: GD Link to comment Share on other sites More sharing options...
TomRhere Posted December 27, 2003 Share Posted December 27, 2003 Sounding more like the switch is going south on you. Works this time, don't work next time, works another time you try it = switch, usually, but not always. Skip That was good! Link to comment Share on other sites More sharing options...
86subaru Posted December 27, 2003 Author Share Posted December 27, 2003 pretty good one , ok, will try again , this time i will put a cold beer on the roof , Link to comment Share on other sites More sharing options...
86subaru Posted December 27, 2003 Author Share Posted December 27, 2003 what is the easiest way to change the wiper switch on a 88 wagon ? Link to comment Share on other sites More sharing options...
