slow wipers
Sorry to keep asking the same questions. But, if it was performing well at driving RPM's then I would say check the connections at the battery and alternator. But you say it is not. What are you using to clean/spray the wiper motor with? You may have some bad solder developing. You may need to scrape and clean or even resolder. Do you have access to another wiper motor? If you do you may want to test it in the system to take the system out of the equation.
Good luck!
Jim, I talked to my brother Mo about this, he called his brother Ron
He said pull the connector on the wiper moter apart??
Drive to Uncle Charlie's waffle house and plug the connector back togeather. Try the way hi speed wipers.
If that does not fix it, he told me my cousin Id had this problem, He consulted my unkle Iot. He said loosen the screw holding the ground wire on the cover of the wiper motor.
Wash the dash board then retighten the screw??
I don't know anything about those things but this is the way my family fixed it
Hope this wipes the smile off your face J/K
