bheinen74 Posted March 31, 2008 Share Posted March 31, 2008 Going to be installing the 4" lift kit this spring on my Brat.....anybody have recommendations for me..... like what stuff do i need for the exhaust (longer hangers?), just general advice......any help thanks. I have front brake extensions, and the steering extension, what about the rear brakes lines? gonna get this all thought out and anything i need. longer radiator hoses? any part numbers or what has worked for you already lifted guys. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted March 31, 2008 Share Posted March 31, 2008 When I install the kits, I extend the rear brake lines, because my lifts lower (lower: as in raise the body off of it) every rear end component except the mustache bar. I use a double female connector with a 4" extension brake line. I put the double female on the line coming out of the body, that goes into the soft line and then attach the extension, then put the extension in the soft line and attach the extension to the double female. As for the exhaust, you should be able to get away with having it mounted in the stock locations, as most of them are attached to the pieces that get lowered. You'll need gas lines, to be safe. Custom-ish radiator hoses (just have to find what fits), pitch stopper might need to be extended, steering shaft extended, and shifter(s) extended. Link to comment Share on other sites More sharing options...
mcbrat Posted March 31, 2008 Share Posted March 31, 2008 if you did a rear disk swap at the same time, you wouldn't need extensions Link to comment Share on other sites More sharing options...
bheinen74 Posted March 31, 2008 Author Share Posted March 31, 2008 oh yeah, and if anybody has a list of tools needed for the install, I will take the list to my dads when i pick up some of his tools to use or at least have in my garage when needed. Mick- I think i am going to drop in all new MWE axles when i do this lift, so i am not so sure about the rear disc conversion, unless maybe you have the parts. I will be pm'ng the iowa guys soon...... Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted March 31, 2008 Share Posted March 31, 2008 Well, depends on if you're buying the kit or building it? If you're just installing it you need: Floor Jack Jackstands Metric Socket set with socket Wrench Metric Box wrenches PB Blaster (just in case) Impact Wrench (can be done without, but makes it easier) Safety glasses (so crap doesn't fall in your eyes) Philips screw driver.... that's all I can think of right now. It's pretty basic stuff. Link to comment Share on other sites More sharing options...
The Dude Abides Posted March 31, 2008 Share Posted March 31, 2008 Johnson']Well' date=' depends on if you're buying the kit or building it? If you're just installing it you need: Floor Jack Jackstands Metric Socket set with socket Wrench Metric Box wrenches PB Blaster (just in case) Impact Wrench (can be done without, but makes it easier) Safety glasses (so crap doesn't fall in your eyes) Philips screw driver.... that's all I can think of right now. It's pretty basic stuff.[/quote'] Ive got 2 xtra heavy duty jackstands if u wanted me to bring them. Ben Link to comment Share on other sites More sharing options...
bheinen74 Posted March 31, 2008 Author Share Posted March 31, 2008 i've got jackstands, and access to all the tools i can ever need (my dad was a mechanic for 40 years) anyways, but i do not have AIR COMPRESSOR at my place......so no impace wrench.... Link to comment Share on other sites More sharing options...
The Dude Abides Posted March 31, 2008 Share Posted March 31, 2008 i've got jackstands, and access to all the tools i can ever need (my dad was a mechanic for 40 years) anyways, but i do not have AIR COMPRESSOR at my place......so no impace wrench.... ok heres the deal as im sure you know. You have 20plus year old car. You are going to need that impact wrench, it will make it go sooooo much faster and easier. Anyone you know have one you can transport easily. Ben Link to comment Share on other sites More sharing options...
bheinen74 Posted March 31, 2008 Author Share Posted March 31, 2008 my dad has 2 compressors (both are HUGE tall standing tanks, too tall to think about moving).. I will check around. ?electric or rechargeable impact wrench maybe? Link to comment Share on other sites More sharing options...
The Dude Abides Posted March 31, 2008 Share Posted March 31, 2008 my dad has 2 compressors (both are HUGE tall standing tanks, too tall to think about moving).. I will check around. ?electric or rechargeable impact wrench maybe? eek with all the stuff youll be moveing i dont know if batter power would last but its something to check into. I only wish i had that type of air compressor lieing around. Ben Link to comment Share on other sites More sharing options...
mcbrat Posted March 31, 2008 Share Posted March 31, 2008 my dad has 2 compressors (both are HUGE tall standing tanks, too tall to think about moving).. I will check around. ?electric or rechargeable impact wrench maybe? This isn't an Iowa vehicle, so should be fine...... but you do know someone with a portable compressor and impact ..... Link to comment Share on other sites More sharing options...
TheYeti Posted March 31, 2008 Share Posted March 31, 2008 Yes, if you have access to an impact, it will help you a TON! I can't wait to see how it all looks when it is done Link to comment Share on other sites More sharing options...
Dynapar Posted April 2, 2008 Share Posted April 2, 2008 I am in the process of lifting my 84 brat right now. Mine is a Minnesota car so it is being special. I do not have an air compressor and things are moving along at a decent pace. Definately have alot of PB blaster handy. You will probably end up needing to get some new bolts and such, as this old stuff tends to break even if you are careful. Make sure you get some anti seize for the reinstall, it will be nice for if you ever need to get anything out again. as for actual tools so far I have used the following: 36mm socket (axle nuts) 2" Wrench (works great for prying off stuck on DOJ cups, not neccessary though) 22mm Socket (diff carrier bolt) 19mm Socket & Wrench 17mm Socket & Wrench 14mm Socket BFH! (one of the most important tools) 3/8" & 1/2" breaker bars Punch set (removing axles) Wire brush (cleaning rusty threads) Thats what I can remember off the top of my head, there are sure to be more. Link to comment Share on other sites More sharing options...
