painter007 Posted April 3, 2008 Share Posted April 3, 2008 does anyone know the configuation of the main plug to the MPFI control unit . the wiring diagrams(Mitchell) that I can find show the main connector to the unit in two rows. one row is numbered 1 to 48 and the other row is 49 to 96. the mpfi cu has two sides with 4 rows of pins each . in the service manual I d/l from the site I can see that the pins are lettered A,B,C,D ,but which is A ,B,C,D on the unit. I would like to know how Subaru numbered the pins,would be much easier to figure out the wiring from the control unit.Thanks Link to comment Share on other sites More sharing options...
s'ko Posted April 3, 2008 Share Posted April 3, 2008 does anyone know the configuation of the main plug to the MPFI control unit . the wiring diagrams(Mitchell) that I can find show the main connector to the unit in two rows. one row is numbered 1 to 48 and the other row is 49 to 96. the mpfi cu has two sides with 4 rows of pins each . in the service manual I d/l from the site I can see that the pins are lettered A,B,C,D ,but which is A ,B,C,D on the unit. I would like to know how Subaru numbered the pins,would be much easier to figure out the wiring from the control unit.Thanks year and model would help in giving you the info. Usually the wiring diagrams that I have seen will have lines to tell you where the plugs end. BW Link to comment Share on other sites More sharing options...
painter007 Posted April 3, 2008 Author Share Posted April 3, 2008 1995 legacy.EJ2.2 I see where the wires go to ,but it would be easier if you know the pin out on the MPFT CU. Link to comment Share on other sites More sharing options...
nipper Posted April 3, 2008 Share Posted April 3, 2008 WHats your email? nipper Link to comment Share on other sites More sharing options...
