MR_Loyale Posted April 5, 2008 Share Posted April 5, 2008 I have never changed the PCV valve on my 93 Loyale. I just looked and I cannot figure out where it is. How dumb is that? I even have the Haynes manual! Yes I am an idiot. But will someone please take pity and tell me where it should be and what it should look like? Quote Link to comment Share on other sites More sharing options...
john in KY Posted April 5, 2008 Share Posted April 5, 2008 Has to be screwed into the intake manifold somewhere. Look around on the backside of the manifold, maybe on the driver's side first. Quote Link to comment Share on other sites More sharing options...
msteel Posted April 5, 2008 Share Posted April 5, 2008 Has to be screwed into the intake manifold somewhere. Look around on the backside of the manifold, maybe on the driver's side first. Yes, it should be screwed in. There will be a "T" and a couple of hoses approximately 3/4" diameter that come out of the back of the air intake (the black rubber thing that says "Subaru FI" on it). The PCV valve should be on the end of one of those hoses. But I don't remember which side either. I think it's pretty easy to see if you take out the spare tire. Quote Link to comment Share on other sites More sharing options...
Bill90Loyale Posted April 5, 2008 Share Posted April 5, 2008 Not a stupid question at all. The intake manifold is a large aluminum casting that is basically mounted to the top of the engine. Look for about a 3/4 inch black hose that appears to be stuck into the manifold on the upper side of the manifold (sort of passenger side IIRC, might be in the middle). The hose may be held on with a spring clamp. The hose attaches to the PCV, which is nothing but a heavy sort of hex bolt (19 mm IIRC) screwed into the manifold. It's torqued down pretty tight, so remember: lefty loosey. Quote Link to comment Share on other sites More sharing options...
DaveT Posted April 6, 2008 Share Posted April 6, 2008 I have never changed the PCV valve on my 93 Loyale. Loyale = EA82 engine. It should be on the intake manifold, directly behind the throttle body on the back. About a 1/2" hose connects to it. Remove the hose, unscrew from manifold. Quote Link to comment Share on other sites More sharing options...
Durania Posted April 6, 2008 Share Posted April 6, 2008 On the bottom one, I believe it to be the brass looking fitting to the 5 o'clock position relative to Japan. Thanks to PoorManzImpreza for the pic. Quote Link to comment Share on other sites More sharing options...
misledxcracker Posted April 6, 2008 Share Posted April 6, 2008 It's directly in the back, behind the throttle body a little bit, screwed in the intake manifold. Quote Link to comment Share on other sites More sharing options...
DaveT Posted April 6, 2008 Share Posted April 6, 2008 Niether of these is an intake from a SPFI Loyale. Quote Link to comment Share on other sites More sharing options...
Durania Posted April 6, 2008 Share Posted April 6, 2008 It's a starting point. Quote Link to comment Share on other sites More sharing options...
msteel Posted April 6, 2008 Share Posted April 6, 2008 OK, found a picture of an EA82 SPFI engine that shows the PCV valve. It is circled in red. There was a change in the hoses from the earlier engines to the later one like your '93. So this '88 might have a different hose configuration. But the PCV valve will be in the same place. Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 6, 2008 Share Posted April 6, 2008 2 hyjack a thread 1 What does the PVC Valve Do 2 If you havent changed it, would you recomend it. I dont believe im haveing any pvc valve problems, but then again i would know what they were. Ben Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted April 6, 2008 Share Posted April 6, 2008 2 hyjack a thread 1 What does the PVC Valve Do 2 If you havent changed it, would you recomend it. I dont believe im haveing any pvc valve problems, but then again i would know what they were. Ben Positive Crankcase Ventilation it removes the unburnrt gases from the crankcase and routes them back thru the intake to be burnt. PCV has an affect on overall engine performace including gas milage. If they become clogged the engine will run rough and on some soobs because the hoses that carry the gases to the PCV are over the exhaust system oil coming up as part of the gases will collect in the hoses and drip on the exhaust causing mysterious oily smelling somke to rise from behind the engine. If your doing a good tune up the pcv valve is as important as anything eles your changing. Lesson over. Quote Link to comment Share on other sites More sharing options...
