mellow65 Posted April 8, 2008 Share Posted April 8, 2008 is there any after market fuel pumps that flow better then stock 1st gen legacys. i have found some walbro pumps for a 2.5rs. has anyone ever fit one of those into a legacy. Link to comment Share on other sites More sharing options...
aircraft engineer Posted April 9, 2008 Share Posted April 9, 2008 OK - this may sound dumb - but why would you need higher flow? at 20mpg at 20mph the flow is 1 gallon/hour. Even at 60 it's 3gph (in this example) 1 gallon every 20 minutes? Most of the pumps I've seen are 1 quart/minute which is about 20X what you need just asking... Link to comment Share on other sites More sharing options...
mellow65 Posted April 9, 2008 Author Share Posted April 9, 2008 a few reasons, one to sound cool two because the walbro fuel pumps are $99 regardless what you get three, the real reason, i'm trying to up my fuel pressure so I figured why not get the biggest i can. i also got the high pressure one too. Why, well because it was $99. i did end up finding out my answer. i ended up ordering a 255lph high pressure walbro pump for a wrx/sti. according to the guys over at legacy central it's a direct bolt in. we will see. Link to comment Share on other sites More sharing options...
