subarubuddy Posted April 10, 2008 Share Posted April 10, 2008 hi everyone. i have a 92 loyale which has been sitting for about a year while i tried to find time and parts to do a rear disc swap. the good news is its finally done. bad news, it was hard to get it running and when it finally started there was lots of white smoke. (it ran fine and didn't smoke when i parked it last year) i first thought head gaskets, but i'm not so sure. i let it run for at least a 1/2 hour, no signs of overheating. it also drives fine. runs pretty smoothly. there's no oil in the coolant. and no coolant in the oil. is there anything else it might be? i haven't done a compression check yet and unfortunately i'm about 150 miles away from the car. {edit} i forgot to mention: it smokes more at higher rpms. like when you rev the engine. doesn't seem to smoke more under load. smokes at idle too-just not as much. Link to comment Share on other sites More sharing options...
idosubaru Posted April 10, 2008 Share Posted April 10, 2008 check all your signs and see what fluids you're loosing - should be oil or coolant. could just be from sitting. how old is the gas - a year or more? Link to comment Share on other sites More sharing options...
Quidam Posted April 10, 2008 Share Posted April 10, 2008 could just be from sitting. how old is the gas - a year or more? Bingo. Not starting an engine for a year could be really bad in your climate. Bore rust, for one. Link to comment Share on other sites More sharing options...
subarubuddy Posted April 11, 2008 Author Share Posted April 11, 2008 yeah . the gas is about a year old. i guess i'll have to check compression and see what fluids dissappear when i drive a while. Link to comment Share on other sites More sharing options...
Andy FitzGibbon Posted April 11, 2008 Share Posted April 11, 2008 yeah . the gas is about a year old. i guess i'll have to check compression and see what fluids dissappear when i drive a while. If the valve stem seals dried out from sitting they could be letting oil (small amounts) into the cylinders. If that's the case it will probably clear up with use. Keep an eye on all fluids, though. Probably not a bad idea to change the oil. Andy Link to comment Share on other sites More sharing options...
john in KY Posted April 11, 2008 Share Posted April 11, 2008 Automatic? May want to check the vacuum modulator on the transmission. Link to comment Share on other sites More sharing options...
mdjdc Posted April 11, 2008 Share Posted April 11, 2008 If the car sat for a long time the exhaust could have loaded up with poisture and that can take a long drive to get it all out. I've had this happen several times and after idling for several hours or a nice long drive the system cooked the moisture out and the smoking stopped never to return. Link to comment Share on other sites More sharing options...
subarubuddy Posted April 11, 2008 Author Share Posted April 11, 2008 If the car sat for a long time the exhaust could have loaded up with poisture and that can take a long drive to get it all out. I've had this happen several times and after idling for several hours or a nice long drive the system cooked the moisture out and the smoking stopped never to return. i actually thought of that too. and i hope so...but the car was smoking pretty bad as soon as i got it running. before the exhaust got hot. Link to comment Share on other sites More sharing options...
