trikerbob Posted April 11, 2008 Share Posted April 11, 2008 Can anyone tell me if the intake manafold off the EA81 motor will bolt up on the EA82 motor? Thanks, Bob:confused: Quote Link to comment Share on other sites More sharing options...
hatchsub Posted April 11, 2008 Share Posted April 11, 2008 yes it will. Coolant hookup is on the back rather than on the front but other than that they line up the same. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 11, 2008 Share Posted April 11, 2008 you will want to carryover the ea81 upper radiator hose to go with to reach the radiator Quote Link to comment Share on other sites More sharing options...
trikerbob Posted April 12, 2008 Author Share Posted April 12, 2008 you will want to carryover the ea81 upper radiator hose to go with to reach the radiator Thannks guys, the radiator hook up wouldn't be an issue in my case as it would be for a Trike and radiators wouldn't be in the same location anyway. Thanks. Bob:banana: Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 12, 2008 Share Posted April 12, 2008 The EA81 intake doesn't flow as well as the EA82, and the carb base is different. GD Quote Link to comment Share on other sites More sharing options...
TomRhere Posted April 12, 2008 Share Posted April 12, 2008 Here's a shot of the difference in size of the carb ports of the manifolds. http://i29.photobucket.com/albums/c264/TomRhere/Weber%20swap%20on%20EA-81%20engine/EA-81EA-82Manifold2.jpg Quote Link to comment Share on other sites More sharing options...
BobBrumby Posted April 12, 2008 Share Posted April 12, 2008 When I did mine a tiny ammount of the altinator bracket hangs up on the underside of the carb base. Just cut off this corner, you will see what I mean, I used a dremel and did it with the bracket still bolted to motor. Also the barb for disty vac adance has to be bent slightly to clear the thermostat housing. Quote Link to comment Share on other sites More sharing options...
Quidam Posted April 15, 2008 Share Posted April 15, 2008 Thannks guys, the radiator hook up wouldn't be an issue in my case as it would be for a Trike and radiators wouldn't be in the same location anyway. Thanks. Bob:banana: You're being awefully quiet. What are you up to? Quote Link to comment Share on other sites More sharing options...
trikerbob Posted April 18, 2008 Author Share Posted April 18, 2008 You're being alwfully quiet. What are you up too? Just saw the intake manafold on Ebay for the EA81 and thought it might be good to have on hand, but I really don't need it as I still have an extra EA82 manafold on hand. The photo you posted, is that a manafold for a Duel port EA82? I would be interested in finding one of those if thats what it is. Looks like that could be machined to fit a Weber carb and not have to use a computer or other wireing. Looks like it would work for my Trike motors. Since I have a pair of duel port heads and an extra high lift cam setup on hand, a duel port manafold fitted to take a Weber 32/36 would be just the ticket. Bob:headbang: Quote Link to comment Share on other sites More sharing options...
Durania Posted April 18, 2008 Share Posted April 18, 2008 Remember to replace intake gaskets with OEM, they're worth the extra price. Quote Link to comment Share on other sites More sharing options...
Quidam Posted April 18, 2008 Share Posted April 18, 2008 The photo you posted, is that a manafold for a Duel port EA82? Bob:headbang: Hey Bob, That manifold in the photo is EA-82T. Nods head on the rest. Doug Quote Link to comment Share on other sites More sharing options...
trikerbob Posted April 18, 2008 Author Share Posted April 18, 2008 Hey Bob, That manifold in the photo is EA-82T. Nods head on the rest. Doug Thanks, does anyone have a good photo of a duel port EA82 non turbo manafold? Bob Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 19, 2008 Share Posted April 19, 2008 Thanks, does anyone have a good photo of a duel port EA82 non turbo manafold? Bob It is excactly the same casting, without the extra coolant line installed. Turbo could be adapted to Non-Turbo or vice-verse. The other type is the "Spyder" intakes that came on the XT MPFI engines. Spyder intake is alot more like an EJ intake with curved runners and a side mounted Throttle body. Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted April 19, 2008 Share Posted April 19, 2008 Remember that the EA82 MPFi & Turbo (dual intake) manifold will not fit an EA81, it only fits EA82 MPFI/Turbo heads Quote Link to comment Share on other sites More sharing options...
Quidam Posted April 19, 2008 Share Posted April 19, 2008 Thanks, does anyone have a good photo of a duel port EA82 non turbo manafold? Bob Hi Bob, You're welcome. Pictures of EA-82 MPFI intakes are around. Some posted recently. Here's a pic I have on hand. '86 EA-82T MPFI. Doug Quote Link to comment Share on other sites More sharing options...
