Durania Posted April 13, 2008 Share Posted April 13, 2008 Sometimes when I pump the gas to get the choke to set, it sometimes causes the secondary to open up and stick on my Brat causing it to rev really high. I in turn, have to get out and push it closed to knock the idle back down. What can I do to keep it from doing this, it has done it since day 1 but only sticks every so often. The spring was installed to cut down on this from happening. Link to comment Share on other sites More sharing options...
TomRhere Posted April 13, 2008 Share Posted April 13, 2008 Two things I can think of that might cause the problem. To much travel of the linkage when you floor the pedal to set the choke. Try adjusting the cable for a bit less movement by turning the adjusting nuts more towards the housing of the cable. A binding of the linkage for the choke and the bellcrank of the throttle cable. Mine did that when I first put the Weber on. Did you put any spacers on the throttle shaft between the Webers linkage and the bellcrank for the cable? That's where mine was binding. I put a couple of flat washers between the pieces there, no more binding. Link to comment Share on other sites More sharing options...
Durania Posted April 13, 2008 Author Share Posted April 13, 2008 Tom, the Brat came with the Weber on it when I bought it. I will check out the cable and see how things do. Thanks. Link to comment Share on other sites More sharing options...
Durania Posted April 13, 2008 Author Share Posted April 13, 2008 This got me to thinking. Is it really opening while I am driving? Link to comment Share on other sites More sharing options...
joostvdw Posted April 13, 2008 Share Posted April 13, 2008 This got me to thinking. Is it really opening while I am driving? Easy, unhook it and go for a ride, if it sounds and drives differently (probably quieter and slower, especially at more than 50% throttle) you know it normally opens when hooked up. Link to comment Share on other sites More sharing options...
Quidam Posted April 14, 2008 Share Posted April 14, 2008 Easy, unhook it and go for a ride, if it sounds and drives differently (probably quieter and slower, especially at more than 50% throttle) you know it normally opens when hooked up. Yep, classic carb tuning...disable the secondarys, dial the primarys in, hook up secondarys, tune, and so on. Doug Link to comment Share on other sites More sharing options...
