discopotato03 Posted April 13, 2008 Share Posted April 13, 2008 Hi all , I need some information on the differences (dimensionally) between L/XT4 and XT6 rear disc backing plates . From the manuals the disc rotor diameters are 226 , 256 , 266mm diameter for L/XT4 , XT6 , 1st Gen Legacy . As I said in the above thread I am exploring the possibilities to see if XT6 type brakes can be made up without their unique components . BTW I have the Aus reproduced rear hubs . Cheers A . Link to comment Share on other sites More sharing options...
Numbchux Posted April 14, 2008 Share Posted April 14, 2008 well.....I posted up some pretty detailed measurements of the 4-cyl backing plate dimensions. it's the same as that, except the caliper is 15mm (30mm bigger rotor, divided by 2) further away. Link to comment Share on other sites More sharing options...
discopotato03 Posted April 14, 2008 Author Share Posted April 14, 2008 So is the XT6 one a modified L/XT4 one or completly different - larger . Does anyone have pics of the XT6 one ? Cheers A . Link to comment Share on other sites More sharing options...
Numbchux Posted April 14, 2008 Share Posted April 14, 2008 it's almost identical. the dust shield part looks different, but it's essentially the exact same thing as the 4-cyl one, but larger. and yes, I just happen to have a picture of one of mine from when I did the swap: Link to comment Share on other sites More sharing options...
discopotato03 Posted April 15, 2008 Author Share Posted April 15, 2008 Thanks for that , you wouldn't have a pic of the other side would you ? Cheers A . Link to comment Share on other sites More sharing options...
Numbchux Posted April 16, 2008 Share Posted April 16, 2008 no, I don't. and I'm not sure when I'll have it apart enough to take one. Link to comment Share on other sites More sharing options...
discopotato03 Posted April 16, 2008 Author Share Posted April 16, 2008 Thank you anyway , am looking to buy some over there and have them sent to me in Australia . Cheers Adrian . Link to comment Share on other sites More sharing options...
Subarutex Posted April 17, 2008 Share Posted April 17, 2008 I have some backing plates in my garage. 99% sure they are xt6 ones i took off my last car. I'd be happy to sell them and ship them provided we can figure out a way to know for sure they are xt6 ones. Link to comment Share on other sites More sharing options...
discopotato03 Posted April 18, 2008 Author Share Posted April 18, 2008 Yes that would be fantastic if they are . I reckon the way to tell would be to measure the inside of the dust cover section as XT6 disc rotors are supposed to measure 256mm diameter where L series and XT4 are 226mm . If the overall diameter of the XT6 plate is known I suppose that would be a good reference as well . Fingers crossed , cheers Adrian . Link to comment Share on other sites More sharing options...
idosubaru Posted April 18, 2008 Share Posted April 18, 2008 i can measure mine for you. it's on the car, but i can take any external measurements of it that you want/need. just let me know, i need to swap my snow tires off of it anyway and will be doing so soon, easy access to measurements for you. just get me exact details of what you want measured. Link to comment Share on other sites More sharing options...
discopotato03 Posted April 18, 2008 Author Share Posted April 18, 2008 I've just measured up a beat up XT4 backplate and is approximately like this . Overall diameter ~ 30cm . The gap between the plates large middle hole and the half round section between the calipers mounting bolt holes 31.4mm . The direct as in shortest distance between the caliper mount holes and the plates large middle hole - 48.8mm . I expect the XT6 plates to be something like 20+mm larger overall and the other measurements approx 10+mm greater . Cheers Adrian . Link to comment Share on other sites More sharing options...
discopotato03 Posted April 19, 2008 Author Share Posted April 19, 2008 Subarutex , from the pic above and FSM's the XT6 ones seem to have a rolled lip on the outer edge facing outwards towards the disc rotor where the XT4 and L series ones are laid back at their outer edge (like a big shallow cone) towards the diff side (inner side) . Also the stiffening "troughs" pressed into the outer stone guard section of the plate seem a lot deeper on XT6's than the 4 cylinder ones which are very shallow I think these may be the way to tell the difference at a glance . Can you let me know which you have please and do you use Paypal ? Someone I know here gets bits sent in from the US for his V8 Dodge so should not be too difficult . Cheers and thanks , Adrian . Link to comment Share on other sites More sharing options...
Numbchux Posted April 25, 2008 Share Posted April 25, 2008 look what I found! pics of the backing plates right after I sand blasted them! the other side of the XT6 plate: the trailing arms, XT6 plates, EA82t plates with and without dust sheilds: Link to comment Share on other sites More sharing options...
zukiru Posted May 11, 2008 Share Posted May 11, 2008 I found the answer to my stupid question great pics! Link to comment Share on other sites More sharing options...
