archemitis Posted December 26, 2003 Share Posted December 26, 2003 i put a high compression ea82 in my hatch, and i think the little starter cant take it. it drains the battery in a few cranks. it has done this to two different batteries. it gets down to about 11.5 volts and wont turn any more. so my question is, should i swap in another ea81 starter. or the starter from the ea82? prolly a dumb question, but does the ea82 starter bolt right on to the ea81 tranny? are they even differnt part numbers? just stumblin through the residual headaches of a converstion here. Link to comment Share on other sites More sharing options...
Guest subu luvr Posted December 26, 2003 Share Posted December 26, 2003 i heard all the starters were the same execpt for auto tranny starters, which are shorter. i couldnt see any difference between ea81 and ea82 starters, unless they were already mixed up when i got em Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2003 Share Posted December 26, 2003 if the starter has an internal short, it will draw mpre amps and put out less power. Link to comment Share on other sites More sharing options...
AlpineRaven Posted December 27, 2003 Share Posted December 27, 2003 Or that the battery is getting old & wearing out and has low CCA (Cold Current Amps) rating same with my wagon, they battery was about to go and had weak starting rating, so wacked in a new battery in, not a problem, or your alternator could be on its way out? Cheers Tristan Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2003 Share Posted December 27, 2003 The EA81 and EA82 starters are identical as far as I can tell - having had both of them apart, and having an EA82 one in my Brat right now.... I think someone said even the EJ starters are the same....... don't quote me on that one tho. GD Link to comment Share on other sites More sharing options...
