dhewitt Posted April 17, 2008 Share Posted April 17, 2008 Two simple Qs: (1) How the heck do you remove the "strap" on the gas cap from the gas cap door? That little plastic "screw" won't budge. (2) Every time I check the oil level in our '03 Outback it reads a bit different. After a change, I fill oil slowly and check often to be sure not to overfill. Once it gets close, I run the engine a bit, let it settle, then re-check and top off. The next day I can pull the stick and it will be a 1/2 inch higher than the notch on the stick. What gives? There must be a better way, or something I'm missing. Link to comment Share on other sites More sharing options...
aircraft engineer Posted April 17, 2008 Share Posted April 17, 2008 well, for the oil - just dump in 4.5 quarts and forget it (4-cyl). the oil level does move around a little bit particularly depending on angle of the car (but not 1/2 quart though) Sump is 4, filter is 1/2. Link to comment Share on other sites More sharing options...
EVOthis Posted April 17, 2008 Share Posted April 17, 2008 yeah every time i do an oil change on any subaru for the most part...i have a hard time reading the oil on the dipstick...like aircraftengineer said as long as you know your dumping in the right amount i wouldnt worry about it....... Link to comment Share on other sites More sharing options...
worknwood Posted April 17, 2008 Share Posted April 17, 2008 Why do you want to remove the gas cap from the plastic strap? It's there to keep you from loosing it. It is a part of your emissions system and if your cap is loose, or not on; your engine light will come on. It gets in the way sometimes but I would not remove mine unless it was to repair or replace. Link to comment Share on other sites More sharing options...
dhewitt Posted April 18, 2008 Author Share Posted April 18, 2008 yep, replacing it. can't get that thing out. Link to comment Share on other sites More sharing options...
jon38iowa Posted April 18, 2008 Share Posted April 18, 2008 dhewitt said: yep, replacing it. can't get that thing out. I couldn't get mine off either. Not a solution, but I simply cut it off. So far I have not lost the new one. Link to comment Share on other sites More sharing options...
dhewitt Posted April 19, 2008 Author Share Posted April 19, 2008 me too. i couldn't take it any more. who needs a leash anyway? Link to comment Share on other sites More sharing options...
aircraft engineer Posted April 19, 2008 Share Posted April 19, 2008 I don't have one on the IMP and wish I did - makes it harder to lose the cap Link to comment Share on other sites More sharing options...
Olnick Posted April 19, 2008 Share Posted April 19, 2008 aircraft engineer said: makes it harder to lose the cap Well . . . ya just gotta' try harder! Link to comment Share on other sites More sharing options...
Bluestone Posted April 19, 2008 Share Posted April 19, 2008 Some years ago, on a previous car, a 1986 Peugeot(yeah, ) I lost the gas cap twice(!), forgetting it at gas stations...cost about $25 each time to replace. I'm rather glad that my Subie's gas cap is attached. Regarding the oil level on the dipstick, I, too, usually have a bitsch of a time getting a correct oil level on my Sube:mad:. I always check the oil on level ground, but it's sometimes under the notch (or hole, if the oil is hot), sometimes over, and often under on one side of the dipstick and over on the other side:-\ Even pulling the dipstick out and waiting for several minutes before shoving it back in and then out again () often gives no satisfaction. I've done that several times in a row, finally determining that my oil is somewhat low, adding some carefully, then finding at the next time I check the level that the oil is a quarter of an inch above the full mark....sigh... I give up!!! I've never experienced such a problem getting a correct oil level reading with ANY other car! Link to comment Share on other sites More sharing options...
