timing alignment help?
so i snapped a timing belt yesterday, and am having some real troubles getting the cams correctly aligned to the crank. i've been doing the routine of:
-distributor side cam pin straight up
-put the crank to the whatever degrees of the timing
-put that sides belt in
-turn the crank over once, so the cam opposite
-put the non-distributor side cam pin straight up
-put in the belt
no luck
please help, what am i doing wrong?
Yeah, you're using the wrong marks. Don't use the numbered TDC scale. Rotate the eninge clockwise another 90 degrees and you will see three lines
Looks like this: l l l
Use the center of those 3 lines as the mark.
