eagleb Posted April 21, 2008 Share Posted April 21, 2008 when i tried to start my car this morning, the car would sound like it was turning over real fast, but didn't feel like the engine was fully turning over. difficult to explain, ut the car definitely won't start Link to comment Share on other sites More sharing options...
Skip Posted April 21, 2008 Share Posted April 21, 2008 be nice to know what "your car" is EJ22 EJ25?? If so, my guess is a broken timing belt. Link to comment Share on other sites More sharing options...
davebugs Posted April 21, 2008 Share Posted April 21, 2008 I think Skip has it. With the limited particulars provided. Link to comment Share on other sites More sharing options...
eagleb Posted April 21, 2008 Author Share Posted April 21, 2008 ej25 obw 120k at. just had a used trans installed a month ago, and some seals replacced on the front end. Timing belt replace around 110k Link to comment Share on other sites More sharing options...
eagleb Posted April 21, 2008 Author Share Posted April 21, 2008 The car had been sitting since friday, and i started it saturday morning with no problems. Worst part is i broke my hand friday and can't really do any work on the car myself. grr. sorry if i leave out any info. I assume a broken timing belt means very bad news for me. Link to comment Share on other sites More sharing options...
davebugs Posted April 21, 2008 Share Posted April 21, 2008 It's an interference motor so yes, bad news for you. Hopefully you've just bent some valves. I'm sure someone else will chime in. I figure pulling both heads, timing belt, etc. at the minimum. I'd just pull the engine to make it all easier to inspect and fix. I recently bought a car where an idler pulley failed and bent the valves. I just put a 2.2 in it. Dave Link to comment Share on other sites More sharing options...
eagleb Posted April 21, 2008 Author Share Posted April 21, 2008 well i'll wait to see the repair quote once i can get the thing to the shop, but it looks like i'll be fixing the car and selling. HG, trans, and now a busted timing belt all within a year and a half. Sad to say, but my confidence is quite shaken. Link to comment Share on other sites More sharing options...
Cougar Posted April 21, 2008 Share Posted April 21, 2008 Since you had the timing belt replaced within the last 10k miles it seems to me the belt should be ok unless something else in the loop caused it to go bad. Link to comment Share on other sites More sharing options...
eagleb Posted April 21, 2008 Author Share Posted April 21, 2008 there was an oil leak from the tbelt cover, but i specifically asked the shop to check it out, just in case. It's possible the belt was compromised, but it could also be another component. The shop is open tomorrow so i just have to wait and see. Link to comment Share on other sites More sharing options...
aircraft engineer Posted April 21, 2008 Share Posted April 21, 2008 An oil leak inside the timing belt cover is usually a bad cam seal. The only other thing in there that can leak is the oil pump - so it's either 1 or both of the cam seals or the main seal. IF the belt got oily, REPLACE IT!! Oil will kill a timing belt very quickly. Link to comment Share on other sites More sharing options...
eagleb Posted April 22, 2008 Author Share Posted April 22, 2008 big question... could this be the starter? engine is quiet, doesnt seem to be turning over, but i can hear the starter still. No metallic noises in the engine... Is there a way to test this without digging into the front of the engine? thanks for any help Link to comment Share on other sites More sharing options...
OB99W Posted April 22, 2008 Share Posted April 22, 2008 when i tried to start my car this morning, the car would sound like it was turning over real fast, but didn't feel like the engine was fully turning over. difficult to explain, ut the car definitely won't start big question... could this be the starter? engine is quiet, doesnt seem to be turning over, but i can hear the starter still. No metallic noises in the engine...I was thinking starter drive problem myself, and was going to comment on that possibility. However, you said "didn't feel like the engine was fully turning over", so I assumed it was at least partially engaged; apparently so did others, hence the suggestions of a broken timing belt. Is there a way to test this without digging into the front of the engine?Are the crank pulley and any driven accessories turning? If not, either the starter drive has failed, or the flywheel gear has missing teeth. If the crank pulley, etc., are turning, unfortunately you're back to the likelihood of a broken timing belt. Link to comment Share on other sites More sharing options...
eagleb Posted April 22, 2008 Author Share Posted April 22, 2008 i apologize for any confusion, I've never had a problem like this before (and vicodin doesnt help diagnosing). When I have some help I'll check the pulleys while crankng. Thank again, I sure hope it is the starter. Then maybe my wallet will stop screaming. Link to comment Share on other sites More sharing options...
OB99W Posted April 22, 2008 Share Posted April 22, 2008 i apologize for any confusion, I've never had a problem like this before (and vicodin doesnt help diagnosing)[...].No apologies are needed. I've been on some heavy-duty painkilling meds myself the last few days, so I can empathize. Good luck -- let us know what you determine, when you get the chance. Link to comment Share on other sites More sharing options...
eagleb Posted April 22, 2008 Author Share Posted April 22, 2008 well, the crank pulley is turning. So much for an easy fix. About how much is a 96 obw at w/ 122k and a 70k transmission worth? Link to comment Share on other sites More sharing options...
spokanesoob Posted April 22, 2008 Share Posted April 22, 2008 wouldn't it turn even if the T belt was broken? or is it different for newer cars Link to comment Share on other sites More sharing options...
Gloyale Posted April 23, 2008 Share Posted April 23, 2008 well, the crank pulley is turning.So much for an easy fix. About how much is a 96 obw at w/ 122k and a 70k transmission worth? Not really. It could still be4 something easy. You are running away with ideas of "OMG!!! my car won't start! it's completely f****d!!" First, have you checked all the fuses? And the fusible links under the hood? Have you checked if there is spark when the engine is cranked? Have you connected the test connectors to read any codes? Is the oil cap on? There is an even longer list of very simple things it could be. People are guessing timing belt because of you're description of the engine turning over fast. That could just be the sound of it turning and not sparking. Check the fuses and fusible links. Test for spark. THEN.... If you find nothing, pull the outer ends of the timing belt covers and inspect the belt. I am betting it's something else, something simple. Link to comment Share on other sites More sharing options...
OB99W Posted April 23, 2008 Share Posted April 23, 2008 [...]There is an even longer list of very simple things it could be. People are guessing timing belt because of you're description of the engine turning over fast. That could just be the sound of it turning and not sparking.[...]Yes, it's difficult to diagnose from thousands of miles away. If only someone were closer... [...]I am betting it's something else, something simple.You may be right. Let's see, Corvallis and Beaverton. Hmmm... Since eagleb has a broken hand and is on painkilling meds, how about a trip of about 1&1/4 hours, east a bit on 20, then north on 5 (at least that's what a Google map seems to indicate), to be sure? Perhaps a person who might benefit from that could pick up the tab for the gas, etc. Link to comment Share on other sites More sharing options...
Gloyale Posted April 23, 2008 Share Posted April 23, 2008 Since eagleb has a broken hand and is on painkilling meds, how about a trip of about 1&1/4 hours, east a bit on 20, then north on 5 (at least that's what a Google map seems to indicate), to be sure? Perhaps a person who might benefit from that could pick up the tab for the gas, etc. I'd be happy to. I must say though that here on the USMB is the only place I *work* on Subarus for free. Getting my hands dirty turning wrenches in RL (real life, as oppossed to this virtual one) is the work I get paid for. That said, I charge very reasonable rates, and would be more than happy to give EagleB an honest, Subaru specific, evaluation and possible repair (depending on what is diagnosed). I could use a reason to go to portland for a few things. Link to comment Share on other sites More sharing options...
keltik Posted April 23, 2008 Share Posted April 23, 2008 would be more than happy to give EagleB an honest, Subaru specific, evaluation and possible repair (depending on what is diagnosed). I could use a reason to go to portland for a few things. Me too but my gas tab is condsiderably higher. Sounds like a starter problem to me. If the t-belt snapped it would probably make a funny cranking rhythm...unless it jumped some teeth and all cylinders happen to have one valve open. Easy test which i used on a car recently was to have an assistant crank the motor at full throttle while i hold my hand over the exhaust. VERY easy to tell if something isnt right (the Impreza i was checking out gave 3 puffs and one suck). Link to comment Share on other sites More sharing options...
OB99W Posted April 23, 2008 Share Posted April 23, 2008 [...]Sounds like a starter problem to me. If the t-belt snapped it would probably make a funny cranking rhythm...unless it jumped some teeth and all cylinders happen to have one valve open.I'd otherwise buy a starter problem, but when I asked eagleb, the response was "well, the crank pulley is turning". As to an uneven cranking rhythm, no one seems to have asked yet -- however, it could have open valves, or "closed" (but bent) ones that aren't sealing, allowing the cranking pace to be relatively even but faster than if there was full compression. Easy test which i used on a car recently was to have an assistant crank the motor at full throttle while i hold my hand over the exhaust. VERY easy to tell if something isnt right (the Impreza i was checking out gave 3 puffs and one suck).Can I assume you dealt with a bad exhaust valve on that cylinder? Link to comment Share on other sites More sharing options...
eagleb Posted April 23, 2008 Author Share Posted April 23, 2008 it feels like theres a lack of compression when turning over, but I don't remember hearing/feeling any uneven cranking rhythm. Mt coil pack is about a year and a half old, so I'm just assuming it's still sending spark. I'll check that tonight. I'm going to see if my mechanic has any spare cam and crank sensors I can use to be sure those aren't the problem. If none of those check out, I'll pull half the timing cover and see if there's any noticeable issues in there. Thanks for the offer to come help, but my dad and a couple of buddies will help me with this easy stuff. If we still can't figure it out, we'll rent a trailer and take it to the shop. There really isn't any room to do serious work at my apt. Aside from fuses/spark/sensors/timing cover, anything else that's easy to check? Thanks again, sorry if my responses are slow. Link to comment Share on other sites More sharing options...
Cougar Posted April 23, 2008 Share Posted April 23, 2008 I would check the compression of each cylinder. This will tell the story of what needs to be checked. Link to comment Share on other sites More sharing options...
keltik Posted April 23, 2008 Share Posted April 23, 2008 Can I assume you dealt with a bad exhaust valve on that cylinder? I informed the seller it wasnt an electrical problem, took my money and ran. A 1995 Impreza manual for $400 and it wasnt worth the money - totally screwed Link to comment Share on other sites More sharing options...
OB99W Posted April 23, 2008 Share Posted April 23, 2008 it feels like theres a lack of compression when turning over, but I don't remember hearing/feeling any uneven cranking rhythm.[...]Unfortunately, there's nothing good that causes lack of compression. If your perception of increased cranking speed is accurate (likely due to lessened resistance from the engine), then that's the thing to investigate. I would check the compression of each cylinder. This will tell the story of what needs to be checked.Exactly! With good compression, checking further for spark, etc., makes sense. However, if there's a compression problem, the rest doesn't matter -- pull the timing belt covers and see what's up, then. Link to comment Share on other sites More sharing options...
