front and rear differential fluids - service?
owners manual is always an excellent reference for stuff like this, which varies with usage. if you don't have one you can usually post in the parts wanted forum or look on ebay and get them for chump change.
auto or manual trans? 1 of the gear oil bottles is enough to fill to capacity, and at 110,000 miles i'd probably change it.
Sounds like you got your answer, though IMO a diff fluid change in the first 5 - 10,000 miles of its life is very wise and helps achieve 'lifetime' fluid fill. I'll often change every 30,000 miles but it depends a bunch on my usage in the vehicle in question.
