hyperlite2 Posted April 22, 2008 Share Posted April 22, 2008 I know that it is on here somewhere, but i can not find it. I want to do a full 5 lug conversion on my ea81 brat. I am confused about which parts i need and what i need to fabricate. There aren't many subarus where i live, so i dont have access to parts to see if i could make them work. Is there a good write up that covers everything on this subject? Thanks, Bryan Quote Link to comment Share on other sites More sharing options...
s'ko Posted April 23, 2008 Share Posted April 23, 2008 Send me a PM and we can talk. here's some info from a thread I started. http://www.ultimatesubaru.org/forum/showthread.php?t=70262 BW Quote Link to comment Share on other sites More sharing options...
Numbchux Posted April 23, 2008 Share Posted April 23, 2008 There are many different ways to assemble a 5-lug swap. so you'll have to do some research, and see which works best for you (which parts are most easily accessible). here's the original list: http://www.ultimatesubaru.org/forum/showthread.php?t=50400 there are some updated lists with pictures and stuff around as well, but that'll give you a pretty good start. The problem with the EA81 swap is the front suspension. the rear end works exactly the same as the EA82 as far as the hubs and brakes are concerned. But the EA81 front track is narrower. and the difference is in the engine crossmember. So, all 5-lug axles will be too long......so you'll need to have some custom axles made. Someone else will have to chime in with the details, but I'm fairly sure that you can't use XT6 control arms on an EA81 either, so you'll need to ream out the ball joint hole on the EA81 arms, or make a sleeve to put the EA ball joint in your ER/EJ knuckles like discopotato did. S'ko did it (as I'm sure you'll see in the post he linked) by putting an EA82 engine crossmember under his brat. but the lift blocks were a crucial part of that.....pretty hard to do it at stock height. also, look for posts by rguyver, he did it in his Brat. But then again......he's an amazingly skilled fabricator :slobber: Quote Link to comment Share on other sites More sharing options...
discopotato03 Posted April 24, 2008 Share Posted April 24, 2008 No No No , please don't attach my handle to the sleeved L ball joint method . My control arms were reamed out L Series ones with a purpose made reamer (part of the Australian Crossbred kit) . XT6 arms have the exact same tapered hole As L series arms , they're just machined further into the arm to give more load bearing area for heavier cars such as XT6's . I reckon the ball and seat in the later XT6/Legacy joint is probably larger and well worth having . Cheers A . Quote Link to comment Share on other sites More sharing options...
Numbchux Posted April 25, 2008 Share Posted April 25, 2008 No No No , please don't attach my handle to the sleeved L ball joint method . oops....sorry, all the recent 5-lug talk has gotten me confused Quote Link to comment Share on other sites More sharing options...
Subarutex Posted April 26, 2008 Share Posted April 26, 2008 No No No , please don't attach my handle to the sleeved L ball joint method . My control arms were reamed out L Series ones with a purpose made reamer (part of the Australian Crossbred kit) . XT6 arms have the exact same tapered hole As L series arms , they're just machined further into the arm to give more load bearing area for heavier cars such as XT6's . I reckon the ball and seat in the later XT6/Legacy joint is probably larger and well worth having . Cheers A . Where can a bloke like me get a reamer like that? Quote Link to comment Share on other sites More sharing options...
discopotato03 Posted April 26, 2008 Share Posted April 26, 2008 From what I remember Gee telling me he had one made so that Crossbred could modify L series arms . I seem to remember him saying that the taper is a common one for automotive ball joints . If really interested I can ask him about it in the next few days . Cheers A . Quote Link to comment Share on other sites More sharing options...
Subarutex Posted April 26, 2008 Share Posted April 26, 2008 Extremely interested... either the taper reamer or in a set of already reamed arms. Quote Link to comment Share on other sites More sharing options...
kiwi subbie Posted April 27, 2008 Share Posted April 27, 2008 i was wanting2 do the same on my brumby. but xt6 stuff is as rear as hens teeth here Quote Link to comment Share on other sites More sharing options...
hyperlite2 Posted April 29, 2008 Author Share Posted April 29, 2008 thanks for all the help guys! sk'o im going to call soon, i just haven't had a lot of time. I'm in the market for parts now Quote Link to comment Share on other sites More sharing options...
discopotato03 Posted May 6, 2008 Share Posted May 6, 2008 Sorry so long , will ask Gee tomorrow . Cheers A . Quote Link to comment Share on other sites More sharing options...
