stray Posted April 22, 2008 Share Posted April 22, 2008 anybody know how to reset the airbag computer after deployment? i've replaced the bag, and the other components were not damaged at all by the impact. the dealership says it's $85 to scan it and "we'll go from there" - i assume that means they'll want me to replace every component in the whole restraint system, before they'll clear it. my local collision centers said they send them to the dealership and let the insurance companies pay for it. i'm hoping someone on here knows if there is a DIY procedure to clear it. thx... Link to comment Share on other sites More sharing options...
Bluestone Posted April 22, 2008 Share Posted April 22, 2008 This may be worth checking out: http://www.myairbags.com/ Link to comment Share on other sites More sharing options...
bheinen74 Posted April 22, 2008 Share Posted April 22, 2008 in all practicality, it will be better (and cheaper) to go get air bag control unit from a non-wrecked junk yard car. I got my whole bag, unit all for 50 shipped from a seller on one of these boards, so the unit alone shouldn't be but like 20 bucks, and that is lots cheaper than paying a dealer 85 to suggest you buy new. You can buy the tamper proof torx needed for this a well for like 10 bucks at sears. Link to comment Share on other sites More sharing options...
aircraft engineer Posted April 22, 2008 Share Posted April 22, 2008 harborfreight.com - http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93388 $2.49 (on sale) or - http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91310 $5.99 with every security driver you could ever want... Link to comment Share on other sites More sharing options...
stray Posted April 24, 2008 Author Share Posted April 24, 2008 in all practicality, it will be better (and cheaper) to go get air bag control unit from a non-wrecked junk yard car. I got my whole bag, unit all for 50 shipped from a seller on one of these boards, so the unit alone shouldn't be but like 20 bucks, and that is lots cheaper than paying a dealer 85 to suggest you buy new. You can buy the tamper proof torx needed for this a well for like 10 bucks at sears. thanks for all of the great advice! i check out the website http://www.myairbags.com and they do subarus for $55, but my year wasn't listed - plus, i didn't wanna wait however long it would take to send it to them and have it returned. so, i called around the local yards. what a wide range of prices! the closest JY wanted $250 for the airbag and computer! yikes!! after a few more calls, i found a couple yards willing to let them go for $25/set. now, that's more like it! (they did break the green/yellow safety clip on the computer, but that's what zip ties were made for, right?) nobody had grey, though. blue is close enough for me. everything is hooked up and good-to-go, no codes. thanks again for your responses. Link to comment Share on other sites More sharing options...
idosubaru Posted April 24, 2008 Share Posted April 24, 2008 stray, thanks for the follow up. i'd like to fix one of mine with a similar situation - front end, air bags deployed. one bag is replaced, the light is still on and non-operational obviously. did you check the sensors on the bumper? did you just replace the air bags and computer and that's it - all was good and the system is operational now? Link to comment Share on other sites More sharing options...
stray Posted April 26, 2008 Author Share Posted April 26, 2008 stray, thanks for the follow up. i'd like to fix one of mine with a similar situation - front end, air bags deployed. one bag is replaced, the light is still on and non-operational obviously. did you check the sensors on the bumper? did you just replace the air bags and computer and that's it - all was good and the system is operational now? i visually checked the front crash sensor - the hit was above it and it was unharmed. i don't know what the procedure is for checking the sensor, i've read some people say they are one-time use and need to be replaced and others say they are re-usable. i'm going with the assumption that if the airbag computer doesn't throw any codes, all is well. the only advice i would give anyone replacing the computer is to be careful unlatching the green/yellow secondary latch holding the main connector. there is a metal wire spring under the green latch, it needs to be pressed inwards, then you can raise the green latch. the jy broke mine removing it, and it is necessary so i had to do some fabricating. other than that, it's pretty straightforward. for some reason, i'm getting 2 cel's after the accident: #35 purge control solenoid or circuit & #49 mass airflow sensor. wonder what caused that? :-\ Link to comment Share on other sites More sharing options...
EVOthis Posted April 26, 2008 Share Posted April 26, 2008 one test i have always felt is reliable to check the MAF is....with the engine running take the butt end of a screwdriver or use your fingers and tap on the MAF....if the engine stumbles or stalls....well than you have a bad MAF sensor...... Link to comment Share on other sites More sharing options...
OB99W Posted April 26, 2008 Share Posted April 26, 2008 [...]i'm getting 2 cel's after the accident: #35 purge control solenoid or circuit & #49 mass airflow sensor. wonder what caused that? :-\Check connections (make sure nothing's loose/hanging) around the right (passenger) side of the engine/bay. Link to comment Share on other sites More sharing options...
idosubaru Posted January 24, 2009 Share Posted January 24, 2009 stray - you still around? i just got done installing all the air bag components (bags, seat belts, computer). everything is hooked up and good-to-go, no codes. did you have to do anything other than install parts? when you started the car, the air bag light went out on it's own? you didn't have to reset anything? if the stuff all came from a good car with the light off...then it shouldn't *know* any different once installed in another vehicle right? wanted to make sure before i reinstall the fuses and turn the thing on. BOOM!!! Link to comment Share on other sites More sharing options...
