Rooster2 Posted April 23, 2008 Share Posted April 23, 2008 How many trany filters does it have? I know there is an external spin on filter, is there also an internal filter under the pan? I am reluctant to drop the pan just to look. I have also heard dropping the pan encourgages leaks upon reassembly. Any advise?? I did a "search," but couldn't find answers. Thanks for any help Link to comment Share on other sites More sharing options...
idosubaru Posted April 23, 2008 Share Posted April 23, 2008 do not replace the internal "filter". it's not even a filter, it's just a screen and they do not get clogged or restricted (i mean i guess they could if your transmission flew apart internally but i'm assuming that's not the case here!) i have replaced them in the past before i finally figured this out. Link to comment Share on other sites More sharing options...
Rooster2 Posted April 23, 2008 Author Share Posted April 23, 2008 do not replace the internal "filter". it's not even a filter, it's just a screen and they do not get clogged or restricted (i mean i guess they could if your transmission flew apart internally but i'm assuming that's not the case here!) i have replaced them in the past before i finally figured this out. Thanks for the advise. I dropped the trany pan on a 91 Leggie, when I had that car. I agree with you. It was simply a fine mesh screen wire that hadn't trapped hardly anything in 100K+ miles. If Subaru still uses the screen, then I won't bother with it. My car has the external AT filter that looks just like the oil filter. It appears to be the original with 160 K miles on it. Maybe, I should replace that one? Link to comment Share on other sites More sharing options...
Olnick Posted April 23, 2008 Share Posted April 23, 2008 Doesn't affect me, but I've often wondered: Why would a manufacturer add a "spin-on external filter" unless it was meant to be changed periodically? Link to comment Share on other sites More sharing options...
idosubaru Posted April 23, 2008 Share Posted April 23, 2008 i would change the external filters based on mileage and time...it's nearly 10 years old. there's really no reason not too. Link to comment Share on other sites More sharing options...
