hatchsub Posted April 23, 2008 Share Posted April 23, 2008 Ive been getting this problem on and off for the last few months and it really bothers me. My throttle linkage is binding really badly these days. I think its binding right between the carb body and the linkage. Is there a good solution to this other than getting the stock hitachi cable guide and adding another return spring? Link to comment Share on other sites More sharing options...
hatchsub Posted April 23, 2008 Author Share Posted April 23, 2008 do they make something like this that would be very very small to use to reduce the friction? some tiny bearings. http://cgi.ebay.com/8-ABEC-7-Speed-Racing-Skateboard-Axle-Ball-Bearings-Set_W0QQitemZ150233265933QQihZ005QQcategoryZ36624QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 Link to comment Share on other sites More sharing options...
Andy FitzGibbon Posted April 23, 2008 Share Posted April 23, 2008 Mine also binds when the engine gets good and hot during long trips. Doesn't stick on, but gets hard to accelerate smoothly. There's someone on here who sells bearing kits for the throttle shaft. Can't remember their user name, but look in the Vendor forum and there's a post about it there. Adding too much return spring tension is hard on the main shaft bushings/bearings, so it's better to fix the problem instead of just adding more tension. Andy Link to comment Share on other sites More sharing options...
hatchsub Posted April 23, 2008 Author Share Posted April 23, 2008 Yea thats big Jim. I actually bought my weber through him. Real nice guy to deal with. I was thinking about that as well and may just do that even though this is a brand new carburator and shouldnt need it. Link to comment Share on other sites More sharing options...
hatchsub Posted April 28, 2008 Author Share Posted April 28, 2008 Anyone got some suggestions or am i looking at putting roller bearing on the throttle shafts? Link to comment Share on other sites More sharing options...
Yo'J Posted April 29, 2008 Share Posted April 29, 2008 I found the end of the oem cable attaching to the hitachi bracket on my weber was rubbing on the fast idle linkage (or whatever it is, in that spot)until I ground it down. I didn't think it was the problem until I had someone else on the petal while I looked. Link to comment Share on other sites More sharing options...
monstaru Posted April 29, 2008 Share Posted April 29, 2008 loosen your throttle shaft nut ever so slightly. hatchsub said: Anyone got some suggestions or am i looking at putting roller bearing on the throttle shafts? Link to comment Share on other sites More sharing options...
hatchsub Posted April 29, 2008 Author Share Posted April 29, 2008 The throttle shaft nut is on hand tight and i still have binding issues. As for the hitachi throttle cable holder thingy (not sure the name) im not using it. Im using whatever cable holder came with the weber new. I dont see any binding between the cable end and the throttle but ill look again later. Link to comment Share on other sites More sharing options...
hatchsub Posted April 29, 2008 Author Share Posted April 29, 2008 Took the linkage all apart, cleaned it, put it back together. It still binds . I made a call to bigjim and bought his roller bearing throttle shaft repair kit. My carb may be relatively new but it already has a bit of play in the main shaft to the point i could feel the idle pick up if i put a bit of downward pressure on the shaft. Stupid plastic bushings. Link to comment Share on other sites More sharing options...
monstaru Posted April 30, 2008 Share Posted April 30, 2008 i had so moany issues with this ;i was cannabalizing other webers for the bushings.that roller bearing sounds like the ticket.cheers,brian Link to comment Share on other sites More sharing options...
hatchsub Posted May 5, 2008 Author Share Posted May 5, 2008 Took it apart today. Replaced the AWEFUL plastic bushings with the roller bearings. SOO much better. No binding now. Smooth throttle. A++ :banana: Link to comment Share on other sites More sharing options...
84SOOB Posted May 5, 2008 Share Posted May 5, 2008 Hey Hatchsub, is it pretty straightforward to replace the bushings or do you have to mess with resetting the throttle plates, etc.---Brian Link to comment Share on other sites More sharing options...
hatchsub Posted May 5, 2008 Author Share Posted May 5, 2008 You have to take the primary throttle plate out but its pretty straightforward in putting it back in. Mine still had dirt lines from where it was before so i just didnt clean it till i bolted it back in. Link to comment Share on other sites More sharing options...
