glfarnes Posted April 26, 2008 Share Posted April 26, 2008 My kids 91 Loyal has a major oil leak on the front of the engine somewhere near the oil pump or base area of the timing belt covers. He doesn't really know the exact location. I see some fresh looking oil at the head/block junction but not enough to prove anything. He pulled the engine, so running it is not an option at this point. Is there any way to pump up the oil on this model without running it? If not does anyone have any recommendations on what seals or gaskets to replace before re-inserting the engine? I also checked the bucket of anti-freeze and looked at the oil and it does not appear to be a head gasket. Jerry Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 26, 2008 Share Posted April 26, 2008 Front crank seal, cam seals, and oil pump seals are likely. Just do them all - you'll find the culprit in the process. Running the oil pump wouldn't do any good unless the engine was turning. Best thing is just to do it all. GD Link to comment Share on other sites More sharing options...
glfarnes Posted April 26, 2008 Author Share Posted April 26, 2008 Front crank seal, cam seals, and oil pump seals are likely. Just do them all - you'll find the culprit in the process. Running the oil pump wouldn't do any good unless the engine was turning. Best thing is just to do it all. GD Would you know of an online exploded view of this thing with part numbers? It would sure make it easier to order parts. Link to comment Share on other sites More sharing options...
desertsubaru Posted April 26, 2008 Share Posted April 26, 2008 Just get a reseal kit from the auto parts store,They come with all you need. http://www.partsamerica.com/ProductDetail.aspx?MfrCode=FEL&MfrPartNumber=CS9390 Link to comment Share on other sites More sharing options...
glfarnes Posted April 27, 2008 Author Share Posted April 27, 2008 Just get a reseal kit from the auto parts store,They come with all you need. http://www.partsamerica.com/ProductDetail.aspx?MfrCode=FEL&MfrPartNumber=CS9390 Thanks: I'll get on it!! Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 27, 2008 Share Posted April 27, 2008 Thanks: I'll get on it!! It's cheaper here Link to comment Share on other sites More sharing options...
MilesFox Posted April 27, 2008 Share Posted April 27, 2008 dont forget there is an oil pump shaft seal. there is also an undersize replacement seal as trhe seal can wear a groove on the shaft. you can also set the seal so it is not riding on the groove. withthe timing belts off, you can spin up the oil pump pulley with a 12mm socker on a drill or impact, clockwise. here is an article if that helps: http://www.economysuperstar.com/milesfox/subaru/service/oilpump.htm 1 Link to comment Share on other sites More sharing options...
idosubaru Posted April 27, 2008 Share Posted April 27, 2008 pulled the engine for an oil leak? is that it? just replace the oil pump seal/oring/gasket, crank seal, cam seals and cam oring (that reside just behind the cam cap that holds the cam seals). all very easy to do in the car, it's all right behind the timing belt. do it all at once and be done with it. install a new belt, oil soaked belts don't last long. a installed a brand new one that got oil on it last summer and it only last a couple months. while it's out replace the valve covers (easy)...and possibly more if you'd like...seal the cams, cam tower orings, head gaskets....wherever you want to draw the line. Link to comment Share on other sites More sharing options...
levonspradlin Posted April 28, 2008 Share Posted April 28, 2008 My 88 has a good sized leak near the drivers side head. I got a kit to do the timing and full gasket replacement. Its a project car to displace my wife's thirsty Lexus V8, so I can take my time. Oddly enough, she likes the Soob. I ride a motorbike daily, so 75mpg will not be replaced for my transport. Would be nice to have heat and a windshield occasionally in the winter, even in Texas! Link to comment Share on other sites More sharing options...
Gloyale Posted April 29, 2008 Share Posted April 29, 2008 Oil leaks dripping up front can also be the Power steering pump leaking down the front of the covers. Just a side note of something else to look at up front for leaks. Link to comment Share on other sites More sharing options...
Robert M Posted April 30, 2008 Share Posted April 30, 2008 Sometimes catching the leak on a clean white napkin can tell you if it's power steering fluid...which will be RED on the napkin. Link to comment Share on other sites More sharing options...
glfarnes Posted May 31, 2008 Author Share Posted May 31, 2008 Johnson']It's cheaper here Aaargh! Yup, it was cheaper, but when I finally got time off to do the job I found out there are no cam seals in this kit. I got them ordered now, so I should get the kid up and running soon. Thanks for all the help! Jerry Link to comment Share on other sites More sharing options...
