Hmmm.....Are you really asking if anyone has heard of this product, or is this a back door approach for a commerical message?
ROOSTER2:
Trust me........no commerical here.
I discovered it a while ago and was just wondering if anyone else uses or has heard of this product. It's not readily available in my area (Philadelphia) and I have to get it via mail order which is a PITA.
~Howard
:banana:
is there a reason you think you need an extra oil additive? changing your oil on your non turbo forester every 3000 miles isnt good enough? how many miles do you have on your vehicle?
SVXPERT:
I have 62,000 miles on it.
Using Lubegard just seems like a good idea.
~Howard
:banana:
lubegard is a very good product. my shop used it mostly for older a/t. i'm not a big fan of addatives if not really needed. in yer case if yer using a good quality oil then i would suggest not using it. tends to change the balance of addatives.
george
Most of the oil additives are combinations of zinc dithiophosphate plus some other things. (Think STP plus a bit of other "stuff")
GENERALLY, it falls into 2 categories - adding "more" to what's in the oil currently - or - trying to make up for missed maintenance that has maybe caused "other" problems.
Usually, it won't "hurt" but it doesn't necessarily "help" either. Your money - 3000 to 4000 mile oil changes will give you the same peace of mind.
You could always dump in a bottle of Slick and try to cover all the bases at the same time
