joostvdw Posted April 29, 2008 Share Posted April 29, 2008 believe me, i've already climbed this hill . . . couldn't agree with the philosophy more . . . (my thread from last month)http://www.ultimatesubaru.org/forum/showthread.php?t=86346&highlight=the+answer just don't think you have the numbers quite right . . . no big deal. chris Try to search a bit in the older posts, preferrably from WJM, he has posted a lot of valuable information in this subject. If you agree with me or not, that's fine, it's good to know we agree on the "feeling good" part Link to comment Share on other sites More sharing options...
cobcob Posted April 29, 2008 Author Share Posted April 29, 2008 I am buying an EJ25 SOHC 170 some odd HP motor for 250when you get the EA82 to 170 crank HP dependably tell me how much it cost you. Unfortunately, what it costs ME and what it would cost the next guy are apples and oranges. I've got access to a full machine shop (mills, lathes, welders, polishers, waterjet, etc.) as well as a lot of scrap material at no cost so there's things that I would be able to do that might not be repeatable w/out someone else spending a whole swag of money. I'm thinking on what route I would use if I was to attempt a build on the EA82T. My main reason for being interested in it is that I have all that stuff at my disposal and an engine gathering dust in my parts car so why the heck not give it a try? Link to comment Share on other sites More sharing options...
Quidam Posted April 29, 2008 Share Posted April 29, 2008 Looking to hypothesize here. IF the HG issue was resolved AND there was sufficient cooling available AND fuel delivery was taken care of, what would be the top HP that you could expect to see out of an EA82T? check-headgasket: you drill and tap for head studs. you have the block align bored and decked, case halves pinned. replace the block bolts with studs. epoxy all studs in If you've done all that, it's got a chance of being reliable. Oh, 75 to 100 hp per cylinder. Doug Link to comment Share on other sites More sharing options...
NorthWet Posted April 30, 2008 Share Posted April 30, 2008 I think that much could be done to deal with the headgasket issue by thinking about where they typically blow: All the ones that I have seen have blown between the cylinder's fire ring and the all-to-adjacent water jacket "eyebrow" passages. Typically, the HG just gets pushed sideways into the passage. I plan on trying collars (similar to headbolt collars) around the water (and maybe oil) passages. "Staking" the headgasket with small pins may also help. "O"-ringing the cylinders themselves probably wouldn't hurt. I also plan on collaring all of the head fasteners. The cooling system needs some real attention, and I was considering providing independent water feeds to both case halves; I believe that the only water passage between the two halves is a "transom" passage at the top of the block, so if water level is low or there is a trapped air bubble (need to make that small bypass at top of block bigger...) then waterflow is compromised. Lots of other thoughts, too, but need to do instead of talk. As far as "why bother with an EA82?" Well why bother with an EJ? Use and EG33 or EZ30... or a VG35 or a 350CID or whatever. No reason needed, jsut wnats he/she wants to do. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 30, 2008 Share Posted April 30, 2008 What ever happened to WJM? He's the one who said, I'm sure others have too, but he's the one I saw say it: "Reliable, Cheap, Power....pick two" that's how you have to build an engine. I have no clue on how much power can come out of an EA82t, but I agree with addressing the common issues...fuel delivery and cooling. I'm going to push my EA82t this summer. Stand alone fuel management (Megasquirt), custom fuel rails, oil cooler, bigger radiator, 2.25 exhaust, and spider intake. Why do this when I could swap an EJ into it? Because, I like the challenge, I like the fact that I have to figure it out. When I do blow the engine up, I'll think of the EJ then, but probably won't do it. I'll learn from the last one and make it better. This guy found out that the 3rd injector failed and caused 3rd cylinder problems. This was back in 1994 or 1995. If you look at the fuel delivery system you'll see that #3 is last in line to get fuel...leaving a theory that it will get starved and run lean. The injectors were sent to RC Engineering in Torence CA for a cleaning and balance. They returned with the report that the #3 injector was pretty bad off when they received it. It is my conclusion that the poor spray pattern and decreased capacity caused the #3 cylinder to run lean, Link to comment Share on other sites More sharing options...
zukiru Posted May 1, 2008 Share Posted May 1, 2008 Johnson']What ever happened to WJM? He's the one who said' date=' I'm sure others have too, but he's the one I saw say it: "Reliable, Cheap, Power....pick two" that's how you have to build an engine. I have no clue on how much power can come out of an EA82t, but I agree with addressing the common issues...fuel delivery and cooling. I'm going to push my EA82t this summer. Stand alone fuel management (Megasquirt), custom fuel rails, oil cooler, bigger radiator, 2.25 exhaust, and spider intake. Why do this when I could swap an EJ into it? Because, I like the challenge, I like the fact that I have to figure it out. When I do blow the engine up, I'll think of the EJ then, but probably won't do it. I'll learn from the last one and make it better. This guy found out that the 3rd injector failed and caused 3rd cylinder problems. This was back in 1994 or 1995. If you look at the fuel delivery system you'll see that #3 is last in line to get fuel...leaving a theory that it will get starved and run lean. you fix that with a nice custom fuel rail with (more) equal length runners. I am noticing all the new headers for EJs are the equal length no boxer rumble type. thumbs way down... Link to comment Share on other sites More sharing options...
carfreak85 Posted May 1, 2008 Share Posted May 1, 2008 I am noticing all the new headers for EJs are the equal length no boxer rumble type. thumbs way down... And also make more power than un-equal length. Two thumbs WAY up! Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted May 1, 2008 Share Posted May 1, 2008 And also make more power than un-equal length. Two thumbs WAY up! Yeah, but then it's just another fast car. The rumble is what makes a Subaru, a Subaru. Thumbs up for the rumble, thumbs down for just another loud fast car. Link to comment Share on other sites More sharing options...
tizzle Posted May 1, 2008 Share Posted May 1, 2008 So I know WJM had set something up for oil coolers, and eventually his source crapped out. What are the current options? Link to comment Share on other sites More sharing options...
audio_file Posted May 1, 2008 Share Posted May 1, 2008 So I know WJM had set something up for oil coolers, and eventually his source crapped out. What are the current options? does an EA82T require something unique . . . because there are many universal oil coolers out there, you just have to decide where you want it mounted, and where your line in and line out are going to be if you really wanna go crazy, you get a thin 12v cooling fan that mounts on either side of the cooler to push or pull air thru it. Link to comment Share on other sites More sharing options...
carfreak85 Posted May 2, 2008 Share Posted May 2, 2008 I don't think we have enough combined dyno experience to really say for sure where the upper limits of EA82T power are. The best we have are those two or three people who have dyno'ed their cars. They have hard evidence, and anything we speculate is just that... speculation. Build it, dyno it and then get back to us. As for the suspension, newer legacy stuff can be modded to work in the rear and pretty much any EJ stuff can be made to work with a front 5 lug conversion. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted May 2, 2008 Share Posted May 2, 2008 I plan on dyno'ing once I'm done, hopefully before I blow the engine. But dyno'ing is expensive. But worth it, if your serious. Link to comment Share on other sites More sharing options...
Quidam Posted May 2, 2008 Share Posted May 2, 2008 I don't think we have enough combined dyno experience to really say for sure where the upper limits of EA82T power are. The best we have are those two or three people who have dyno'ed their cars. They have hard evidence...snip...Build it, dyno it and then get back to us. It might take me a year:) It's all about pressure. My estimate is that there's never been but a couple handfulls or less of serious EA-82's built. Built the right way. Tuned the right way. The ignition system. The fuel system. The cooling system. You mess one of these up making big numbers, that engine is toast. Run it lean, never. Too much spark advance for the fuel, never. Cooling system, you better have it together and figured out. And, a dyno is just a measuring device. Like lots of others. It ain't all it's cracked up to be. /me who has been sweating over an EA all day. Doug Edit: What I'm wondering is, has anyone here, first hand knowledge of an EA-82 block being decked? Link to comment Share on other sites More sharing options...
Quidam Posted May 2, 2008 Share Posted May 2, 2008 I think that much could be done to deal with the headgasket issue by thinking about where they typically blow: All the ones that I have seen have blown between the cylinder's fire ring and the all-to-adjacent water jacket "eyebrow" passages. Typically, the HG just gets pushed sideways into the passage. I plan on trying collars (similar to headbolt collars) around the water (and maybe oil) passages. "Staking" the headgasket with small pins may also help. "O"-ringing the cylinders themselves probably wouldn't hurt. I also plan on collaring all of the head fasteners. The cooling system needs some real attention, and I was considering providing independent water feeds to both case halves; I believe that the only water passage between the two halves is a "transom" passage at the top of the block, so if water level is low or there is a trapped air bubble (need to make that small bypass at top of block bigger...) then waterflow is compromised. Lots of other thoughts, too, but need to do instead of talk. Edit:Borescoped the heads, SPFI and MPFI. /me still not clear on this point. Well, not absolutly certain on, oh NM:) Link to comment Share on other sites More sharing options...
ausubaru92 Posted May 3, 2008 Share Posted May 3, 2008 There was QuikRX from Australia that built an EA82T that has about 260bhp & 420Nm's of torque with the VF-10 at 18psi. It is now in the hands of a new owner and the last i heard, he was still breaking gearboxes. Link to comment Share on other sites More sharing options...
mykingcrab Posted May 3, 2008 Share Posted May 3, 2008 :popcorn: :popcorn: :popcorn: Link to comment Share on other sites More sharing options...
kiwi subbie Posted May 4, 2008 Share Posted May 4, 2008 well if some one had the money send it to an good tunning shop. they rebuild it and do there stuff 2 it. get massive power and be relible too. Link to comment Share on other sites More sharing options...
