Hi All-
I was hoping somebody could help me with a turn signal/hazard problem. Both stopped working. I get no dash indicator either. When I hit the turn signal switch or the hazard switch, I hear a single click under the dash but no lights. Is it the flasher unit?
If so, can anybody tell me where under the dash it is located? Also, I have called AutoZone and my local auto parts store. Neither one has it listed. Is it a dealer only part?
Thanks in advance!
:confused:
Hmmmm. When I went to install a new radio and a new dash clock in my 02 Outback Sport, I had to unplug the switch that controls the hazards. I needed to drive somwhere before the install was done, and guess what - no turn signals. Turned around, went home, plugged the switch back in, and they worked.
My guess is the switch is dead. But that's just a guess. I know nothing.:)
Its a failed flasher. The flasher is solid state, so it needs power to operate. If its a failed bulb, you would blink twice as fast.
Things to check
Are the blinkers working outside the car?
Does the 4 way flash?
Is the fuse good?
It's going to be a dealer item since they rarely go bad.
On a legacy its near the fuse panel on the lefthand side under the dash. A Dealer should be able to help you find it.
nipper
Things to check
Is the fuse good?
nipper
No blinkers on the outside. No 4-ways and fuse looks good. I can hear the relay click under the dash when I hit the switch but that is all I get. :(
I wouldn't imagine it would very expensive from the dealer, but just in case it is, I should have a replacement if you're interested in a used one. I've got a "spare" '99 OBS I've stripped.
