timing mark
Mitch I like to take just number one plug out (pass.side front) and put a plastic soda straw in the hole a short way (3 or so inches)
Put a 7/8" socket on a ratchet turn engine clockwise till the straw moves. Either stroke (comp or exhaust) will yield the timing marks in the window. 10, 0, 10, 20 BTDC
Another way is to pull the dist cap and turn the engine until the rotor points at number 1 or 2 spark plug wire tower.
Ed's idea on paint is way kewl (I use a yellow paint stick).
DO NOT forget to plug the green connectors together when you check/set the idle speed timing. (23 deg BTDC)
Then unplug when done, these are beside the ECU under the trim panel under the steering col.
Hope this helps
These green connectors your referred to? You mean the Check Engine Light wires? And would I have to connect the two green ones if I was adusting my timing on a non turbo?
Hope this helps
plug them in for spfi and turbo. the old models have them in the kick panel, and 88 and up have them under the hood
plugging them in prevents the dist from advancing when setting the timing initially. the electronical sense of disconnecting the vac advance on a carm
Sorry Donald, to my knowledge they never were in the kick panel.
The Spfi units have them under the hood in the area by the drivers side hood hinge
Turbo units have them to the left side of the ECU which is near the steering column,
not in the kick panel. But just above your knees while driving. The trim panel under the
steering column must be lowered.
Just wanted Mitch to be able to find them.
The manuals will also tell you to have the "idle switch" closed.
This switch is incorporated in the throttle position sensor (TPS) and will be closed
if the car is idling properly.
BTW these green connectors are called "test mode" connectors
The ones normally used for checking trouble codes are black on turbos
and white or black on the SPFI and are called "read memory" connectors.
Both found in the same general area as the "test mode" connectors
Thanks for all the advice. I would do it today but i broke my clutch ankle snowboarding last night. It was a fun drive home. Looks like i'll be surfing the web today. Just a quick question about the idle, should i set it exactly to 700 or can it be anywhere from 600-800?
