smithe Posted May 6, 2008 Share Posted May 6, 2008 Been searching the forums and all over the internet in general with no luck. Thanks in advance. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted May 6, 2008 Share Posted May 6, 2008 I believe any other EA82 GL. Link to comment Share on other sites More sharing options...
jacobs Posted May 6, 2008 Share Posted May 6, 2008 Convert lights to a DL Link to comment Share on other sites More sharing options...
Gloyale Posted May 6, 2008 Share Posted May 6, 2008 85,86 is an excact replacement 87+ will work and bolt in, but the headlight adjusters will interfere with the grill, very slight bending/cutting would be needed. Link to comment Share on other sites More sharing options...
edrach Posted May 7, 2008 Share Posted May 7, 2008 Gloyal is correct, '85 and '86 are exact replacements. I've used '87 and later by just bolting in the bracket to the fender which the same for all years and then using a tie wrap to secure the inner support. No cutting or bending required. The other althernative is to remove the headlamp from the '87 or later bracket and install it in the '85/86 bracket. That's a bit of a pain but it can be done. Link to comment Share on other sites More sharing options...
smithe Posted May 7, 2008 Author Share Posted May 7, 2008 Thanks for the advice, hitting the pull and save this week and if they have any, I am all over them, plus some other items. Link to comment Share on other sites More sharing options...
