Is anyone using water methanol injection on theor EA82T ?
Oldsmobile used water injection on their turbocharged high compression 1962 or maybe it was 1963 aluminum block V8 from the factory. The compression ratio was somewhere around 10:1 or 11:1...I think.
I'm sure it would work IF you set it up properly AND don't forget to keep water in the reservoir.
Edit: See http://auto.howstuffworks.com/1962-1963-oldsmobile-f85-jetfire.htm
Ive read about this in a mustang 5.0 and superfords mag. the person that got it done to his car said it ran alot cooler than with out it. its pretty much like the Cryo2 system except it is injected into the engine than run through piping to cool engine componets. i would surely use it
Gannon the big thing is the WMI's control system , the most effective versions use either manifold pressure signal or 0-5v MAF sensor output to regulate the WM switch/ramp functions .
Cheers A .
Actually no, the best ones use Fuel injector duty cycle to calculate the water/meth ratios
