archemitis Posted December 29, 2003 Share Posted December 29, 2003 i marked the flywheel of my ea81 to work on my ea82. and if you are familure with both motors, both have a hole cut in the engines bell housing to view the timing marks. the ea81 is off to the side on the passenger side. and the ea82 has a hole right on the top. probably 40-60 degrees apart. but when i marked my ea81 flywheel, it only needed to be marked 10 degrees later, than the ea81 marks. im wondering why? it seems like it would be way off, just like the timing holes, in the bell housing, but they are rightnext to eachother. is anyone following me here? im just wondering why the timing marks are so different, but so close. Link to comment Share on other sites More sharing options...
MilesFox Posted December 29, 2003 Share Posted December 29, 2003 well, between the two flywheels, the crank orientation looks to be the same but the marks are off depending on the location of the timing window, even though the flywheel to crank orientation is the same..... Link to comment Share on other sites More sharing options...
archemitis Posted December 29, 2003 Author Share Posted December 29, 2003 thats what i thought, but when i marked mine, it was only 10 dergrees off. Link to comment Share on other sites More sharing options...
MilesFox Posted December 29, 2003 Share Posted December 29, 2003 maybe it has to do with the number of teeth on the dostributor gear ohc vs in block cam Link to comment Share on other sites More sharing options...
WRX1AB Posted January 7, 2004 Share Posted January 7, 2004 I( had the same problem. I gave up and timed it by ear Link to comment Share on other sites More sharing options...
