I've done a search for this code on the site and it seems to have something to do with the venting of fuel gases. I have no idea where the parts are for this or which ones to replace or test or inspect.
Any direction would be much appreciated.
the entire evap system helps remove vapors in fuel system...i believe the control/purge valve opens and closes the system as necessacary....there is a chance i am slightly wrong though.......
I was doing some fuel system maintenance a couple weeks ago and when I added seafoam to the tank, more of it ended up on the ground than in the tank. Is there a potential relation between these two events?
Depends on why and how it wound up on the ground. For example, if it went down the filler neck without backing up, you might have a rusted through fuel filler tube.
