jchipper Posted May 7, 2008 Share Posted May 7, 2008 is it possible to tow my 90 legacy with a tow bar for 800 miles w/o damage to the tranny? it's a 5 spd... or will i need to remove the drive shaft and axels? Link to comment Share on other sites More sharing options...
idosubaru Posted May 7, 2008 Share Posted May 7, 2008 read or get an owners manual or do a search here/internet. in the end if you're still wondering, i would disconnect the driveshaft, it's REALLY easy. no need to remove any axles, that's way too much work! Link to comment Share on other sites More sharing options...
Gloyale Posted May 7, 2008 Share Posted May 7, 2008 jchipper said: is it possible to tow my 90 legacy with a tow bar for 800 miles w/o damage to the tranny? it's a 5 spd... or will i need to remove the drive shaft and axels? If you mean a tow BAR on the front of the car, leaving all four wheels on the ground, then you will be fine. If you mean a Tow DOLLY, which puts the front wheels off the ground, and only the rears roll, then NO. Definately not. Either tow it flat with all 4 on the ground(manual trans only) or flatbed it. IF you REALLY need to put it on a dolly, you must disconnect the center driveline like mentioned. Link to comment Share on other sites More sharing options...
jchipper Posted May 7, 2008 Author Share Posted May 7, 2008 Yes Tow Bar with all 4 wheels on the ground... Link to comment Share on other sites More sharing options...
gbrand Posted May 8, 2008 Share Posted May 8, 2008 also since it is a 90....is it a FWD or AWD.....As years go by I have had people try to tell me I can't tow my 91 Legacy FWD with the front off the ground...whic would be correst if it was an AWD.....too used to assuming ALL subes are AWD..... Link to comment Share on other sites More sharing options...
jchipper Posted May 8, 2008 Author Share Posted May 8, 2008 on the dash it says Full time FWD Link to comment Share on other sites More sharing options...
wtdash Posted May 8, 2008 Share Posted May 8, 2008 jchipper said: on the dash it says Full time FWD Is that a typo?....Mine says Full Time AWD. I doubt that the FWD cars got a sticker. Yes, all 4 wheels on the ground is OK w/the 5 spd...no towing an Automatic w/ANY wheels on the ground. Good luck! Link to comment Share on other sites More sharing options...
jchipper Posted May 9, 2008 Author Share Posted May 9, 2008 Went and double checked and it says Full time 4WD Link to comment Share on other sites More sharing options...
johnceggleston Posted May 9, 2008 Share Posted May 9, 2008 jchipper said: Went and double checked and it says Full time 4WD so this means all 4 wheels off the ground when towed or all 4 wheels on the gorund (in neutral) when towed.your choice. if your tow vehicle is big enough, a car carrier is easiest, assuming you can drive your subaru up on it. Link to comment Share on other sites More sharing options...
