spokanesoob Posted May 9, 2008 Share Posted May 9, 2008 nobody in town has the whole reseal kit. so i was wondering if i could get away with just doing the mickey mouse gasket and possibly get the rest of the kit later? im super strapped for cash and i need to get my car going tomorrow also does anybody in spokane have a clutch alignment tool i could borrow? the car is a 88rx i was also wonderin where i put selant on the block when im puttin the oil pump on. thanks. spokanesoob Link to comment Share on other sites More sharing options...
idosubaru Posted May 9, 2008 Share Posted May 9, 2008 of course you can. not the best idea but that's for you to decide. RTV goes at noon and 6 oclock on the oil pump housing or engine block. basically look for the very fine zig-zag pattern where the two block halves meet, that is where the RTV is supposed to go. Link to comment Share on other sites More sharing options...
azsubaru Posted May 9, 2008 Share Posted May 9, 2008 Do what you have to do. You can get away with just the mickey mouse gasket, but you may still have leaks, and have to take it all back out before very long. tip from grossgary (search "oil pump"+sealant): Use anaerobic sealant or RTV very lightly at the 12:00 and 6:00 positions, where the pump meets the engine block, just where the two halves of the engine block come together. Also check out Miles Fox's Oil Pump repair info at http://www.economysuperstar.com/milesfox/subaru/service/oilpump.htm Link to comment Share on other sites More sharing options...
Urabus-84HBDR Posted May 9, 2008 Share Posted May 9, 2008 well you should give me a call... i can get the complete oil pump kit, mickey mouse o-ring and one other single o-ring. i think the pump just mounts directly onto the block, no gasket there... could be wrong. also i definately have a clutch alignment tool you could borrow- as long as i get it back. give a call man.... im willing to help just have to let me know when and where. spokanesoob said: nobody in town has the whole reseal kit. so i was wondering if i could get away with just doing the mickey mouse gasket and possibly get the rest of the kit later? im super strapped for cash and i need to get my car going tomorrow also does anybody in spokane have a clutch alignment tool i could borrow? the car is a 88rx i was also wonderin where i put selant on the block when im puttin the oil pump on. thanks. spokanesoob Link to comment Share on other sites More sharing options...
spokanesoob Posted May 9, 2008 Author Share Posted May 9, 2008 Urabus-84HBDR said: well you should give me a call... i can get the complete oil pump kit, mickey mouse o-ring and one other single o-ring. i think the pump just mounts directly onto the block, no gasket there... could be wrong. also i definately have a clutch alignment tool you could borrow- as long as i get it back. give a call man.... im willing to help just have to let me know when and where. ok i will prolly give you a call sometime tommorow or sunday if that is cool with you. i really need that clutch tool. i'm buing the gasket today so i think its too late to get the whole kit Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 11, 2008 Share Posted May 11, 2008 You don't need a clutch alignment tool for any EA subaru. I haven't used one in years. Eyeball the disc. Leave the bolts for the PP loose so you can just slide the disc around but it doesn't flop like a dead fish. Install the tranny. Tighten the PP bolts through the starter hole. GD Link to comment Share on other sites More sharing options...
MilesFox Posted May 12, 2008 Share Posted May 12, 2008 a/8' socket extension fits in the polit hole. wrap the extension in tape to meet the diameter of the clutch disc Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 12, 2008 Share Posted May 12, 2008 MilesFox said: a/8' socket extension fits in the polit hole. wrap the extension in tape to meet the diameter of the clutch disc I just did something similar on a Ford Contour - worked fine.. But there's still no need on an EA - tighten through the starter hole. GD Link to comment Share on other sites More sharing options...
baccaruda Posted May 12, 2008 Share Posted May 12, 2008 the starter hole trick is super great to know. It's a little hard with a standard box/open wrench, but one with an offset neck is perfect for this. I'd rather carry such a wrench than a clutch alignment tool, becuse the wrench will be useful for more than one thing. I will use the tool if I have one, though, because it's faster. Link to comment Share on other sites More sharing options...
