How do you check anti-dieseling valve
I was just wondering if anyone knows how an anti-diesling valve on the Hitachi carb can be checked to determine if it is operating properly. I have a 76 wagon 1.4L engine. Also, what would be the consequences of just removing the little plunger in there if I suspect it may be malfunctioning?
well, as the name implies it's anti-dieseling... so if you remove that function it won't be able to instantly cut the fuel and if the engine is warmed up it will continue to run and burn the excess gas in the line until it slowly sputters to a halt...
personally, I like my car to stop running when I turn off the key... (:
--Spiffy
there could also be some gunk in there causing it not to open or close all the way...
like waimaks said, take it out and clean it... it about the easiest thing to remove from a carb...
--Spiffy
