TheBush Posted May 9, 2008 Share Posted May 9, 2008 So...here's the scoop on my 1986 Turbo Wagon.... Did all new headgaskets, and other gaskets, such as intake, exhaust, turbo, etc. Anyways....so tried to fire it up the other day, and no luck. getting fuel pass the fuel filter (the one in the engine bay) and everything.... so, replaced the fuel pressure regulator....and it started up, and ran...last night was good and stuff...then it started to sputter a little bit. but still ran. This morning, I tried to take it to school. Got a mile away from home, and it started sputtering, and basically just died. So I pulled it to the side of the road. Then, It would barely start up, and then just die. I thought maybe it was out of gas, even though the digidash told me it was fine. Put gas in it...It won't even start now. What the hellllll????? Any help? Link to comment Share on other sites More sharing options...
zukiru Posted May 9, 2008 Share Posted May 9, 2008 check for fuel past the filter again. re check the fuel regualtor. try pushing the throttle pedal while you try to crank it. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted May 9, 2008 Share Posted May 9, 2008 How did you do the timing? DId you follow MilesFox's procedure? If you Followed the Haynes manual, I can almost guarentee that it was done wrong, I did. Here's the Link to the procedure. Link to comment Share on other sites More sharing options...
MilesFox Posted May 9, 2008 Share Posted May 9, 2008 fuel pump? you can plug a fuelpressure gauge to the hose into the filter and plug in the green test clips to cycle the fuel pump. test it there, then after the regulator(while running the fuel pressure regulator is on the return side of the fuel injectors Link to comment Share on other sites More sharing options...
Gloyale Posted May 9, 2008 Share Posted May 9, 2008 This morning, I tried to take it to school. Got a mile away from home, and it started sputtering, and basically just died. So I pulled it to the side of the road. Then, It would barely start up, and then just die. I thought maybe it was out of gas, even though the digidash told me it was fine. Put gas in it...It won't even start now. Check you're rotor screw. Check the MAF tube. Check that fuel line is hooked to correct tube. Fuel line should NOT go to the pipe with the regulator on it. The regulator is on the return side of the injectors. Link to comment Share on other sites More sharing options...
MilesFox Posted May 9, 2008 Share Posted May 9, 2008 on the fuel rail, the line topmost in th emiddle is the supply line, the other is the return line. the smallest of the 3 hoses is the charcoal canister vent line from the tank. Link to comment Share on other sites More sharing options...
Cougar Posted May 10, 2008 Share Posted May 10, 2008 Another easy thing you can do is see if it will start when you spray some starter fluid into the intake. If it does then the fuel system has another problem. It may be a bad filter near the pump. Link to comment Share on other sites More sharing options...
