EVOthis Posted May 13, 2008 Share Posted May 13, 2008 so i was taking a look at my 96 legacy today and i had it up on a lift and i started shaking the passanger front wheel to notice any movement....i noticed a little movement when i grasped the wheel at 6 and 12 oclock and gave her a shake....enough movement that you feel it but you cant really see it.....i also grasped the tire at 3 and 9 oclock and i had NO movement there....the ball joints are good and the tie rods are good.....i did take a look behind the wheel and i notice NO movement where the axle meets the hub when i give her a shake.......i notice no noise when coming from there while driving.......my question is how much movement is considered "normal"?.....i dont belive its my wheel bearings....because i dont hear anything........any help would be appreciated...... Quote Link to comment Share on other sites More sharing options...
frag Posted May 13, 2008 Share Posted May 13, 2008 so i was taking a look at my 96 legacy today and i had it up on a lift and i started shaking the passanger front wheel to notice any movement....i noticed a little movement when i grasped the wheel at 6 and 12 oclock and gave her a shake....enough movement that you feel it but you cant really see it.....i also grasped the tire at 3 and 9 oclock and i had NO movement there....the ball joints are good and the tie rods are good.....i did take a look behind the wheel and i notice NO movement where the axle meets the hub when i give her a shake.......i notice no noise when coming from there while driving.......my question is how much movement is considered "normal"?.....i dont belive its my wheel bearings....because i dont hear anything........any help would be appreciated...... Just repeating what I've read here numerous times : put your hand on the strut/spring and if you feel vibrations when you spin the wheel, then the bearing is at least starting to go. Quote Link to comment Share on other sites More sharing options...
EVOthis Posted May 13, 2008 Author Share Posted May 13, 2008 thanks frag....i will def give that a try tomarrow.....appreciate the response Quote Link to comment Share on other sites More sharing options...
EVOthis Posted May 14, 2008 Author Share Posted May 14, 2008 well i didnt notice any vibration from when i grabbed the spring or strut.....the whole thing is prob. just me being paranoid.... ....thanks for the help though frag Quote Link to comment Share on other sites More sharing options...
