Hendrik Posted May 15, 2008 Share Posted May 15, 2008 I already talked about this case in an earlier thread , http://www.ultimatesubaru.org/forum/showthread.php?t=87795 , but since it became clear now , after some tanks of gasoline , that the failure was present much more time in the past. Even if it might be seldom with failing injectors , over the time I ownded the car , I spoiled quite an amount of mony in using too much gas , as well as for other parts. Hope that this info might help others.............. The impreza 1993 , awd, auto , 1,8 L , never was economically. But the last months where very bad , may be 10 miles per gallon. 10 thousend miles ago , I always had problems with long downhill trajects , one plug stopped working for cilinder1 . Renewed all electical ignition parts , filters etc. Became better , but not solved completely. Always at certain rpm's the engine seemed to run on 3 cilinders...especially without a certain load. Now everything is different , the engine runs smooth , no more black exhaust , the tank gauge does not seem to move anymore.. One injector never closed completely , and so it used exessive amounts of gas. The faulty injector did it ! Link to comment Share on other sites More sharing options...
frag Posted May 15, 2008 Share Posted May 15, 2008 Cool! How did you find the faulty injector? Link to comment Share on other sites More sharing options...
Hendrik Posted May 15, 2008 Author Share Posted May 15, 2008 frag said: Cool!How did you find the faulty injector? Try and error. The faulty one had a resistance of less then 7 ohms , normal is 12-15 ohms. Just read the earlier treads. Link to comment Share on other sites More sharing options...
