May 19, 200817 yr So i picked up these mazda b2000 wheels with tires for 50 bucks which isnt bad. But im looking at the depth of these things. About 6 inches and im thinkin there going to stick out. The guy said they sat on his truck fine but im having a hard time not seeing them stick out on my 88 dl wagon. These dont look like factory truck wheels they are more like these http://www.uswheel.com/wheel.cfm?category=65 14 x 6 Also the only way i guess to really be sure is to throw them on right. Well easier said than done. Either i drill out the wheel and possibly destroy getting my money back. Or takeing the time to disasemble my car and drill out those holes to see if that works. Putting my car out of comission Any Advise. Ben
May 19, 200817 yr If you have a spare hub knock two studs out and mount up just for a look. I dont see why you couldn't put it on the ground so long as you don't drive it. I don't think the hubs would be very expensive at PAP.
May 19, 200817 yr Author in the midwest subies are a rairty in the junkyard. Is there a way i could knock out 2 studswith the hub still on the car then put them back in after ive checked it. Ben
May 19, 200817 yr Is there a way i could knock out 2 studswith the hub still on the car then put them back in after ive checked it. Sure, but CAREFULLY. Looking at the wheels you linked to the offset is 0, making the hub sit exactly in the center of the wheel tire combo, so taking a tape measure (divide the overall width by half), and measure out from the face of the hub this distance, and sighting down your fender you can get pretty close to the amount the tire is going to hang out.
May 19, 200817 yr Author Is there a way i could knock out 2 studswith the hub still on the car then put them back in after ive checked it. Sure, but CAREFULLY. Looking at the wheels you linked to the offset is 0, making the hub sit exactly in the center of the wheel tire combo, so taking a tape measure (divide the overall width by half), and measure out from the face of the hub this distance, and sighting down your fender you can get pretty close to the amount the tire is going to hang out. How do i remove the hub then how do i remove the studs. Ben
May 19, 200817 yr what's the backspacing measurement. (distance from rear lug mount surface to back edge of rim... I have 3 different suby pattern 14x6 wheels we can compare the measurements to. then testfit on yours for reference:
May 20, 200817 yr So I calculated the offset of the rim roughly and they are about 26mm offset. I used to run 25mm on my EA81 and they are perfect. 23mm stuck out a little. EA 13"x5.5" wheels are around 58mm I think. So I'd say your fine. They will work good. Just because a wheel works on one car doesn't mean it will on all. Different brands, ages, models etc use different fender overlap. Some 4x4's even have factory flairing and use less offset or even negative offset rims.
