mike mcneil Posted May 20, 2008 Share Posted May 20, 2008 Hi. just bought 88k mi soob. any ideas why all that stuff wouldn't be working. car sat in a damp garage for a year. new alternator installed a couple years ago. thx! Link to comment Share on other sites More sharing options...
bheinen74 Posted May 20, 2008 Share Posted May 20, 2008 damp garage = this probably need to check ALL the electrical connectors under the hood to start, use electrical contact spray cleaner, and then put Di-electric grease in the connectors. And watch out for critters Link to comment Share on other sites More sharing options...
Cougar Posted May 21, 2008 Share Posted May 21, 2008 Check to see if the ignition switch is working correctly. There is a white wire that supplies power to the switch and there is a blue wire that is switched power to the fuse panel. There is a connector under the steering column that can be a problem also tied to the switch. Link to comment Share on other sites More sharing options...
mike mcneil Posted May 22, 2008 Author Share Posted May 22, 2008 Thanks for the advice. I cleaned electrical connections today. The windows quit because wires going into plugs under driver's seat had corroded completely off. Rewired & windows work! All the electrical contacts under the hood were corroded. Also, I figured the contacts in the wiper switch must be corroded too so I flipped the switch on & off about 50 times fast & the corrosion must have worn off because the wipers now work. I'll check the ignition switch tomorrow. Thanks again for your help Mike Link to comment Share on other sites More sharing options...
Hondasucks Posted May 22, 2008 Share Posted May 22, 2008 Also check the fusible links, I forget exactly where they are on an EA81 car, but they are in a little black box, should be two green and one red, or two red and one green, I can't remember exactly... Also, be careful with the contact cleaner, some of it is harmful to plastic and will melt your connectors. Link to comment Share on other sites More sharing options...
